door locksmike1224 05-19-2004, 04:54 AM the lock will fall inside the door panel when I put in my key. I never had this problem until I had a security alarm installed, i don't have power locks, so i have to unlock the door through the passenger side, theres been a few people that I have spoken to, and they have had the same problem. What, if any are some solutions to fix this problem? TopDogg 05-19-2004, 10:21 PM THere is probably something like a C-clip made from spring steel that should be holding it in from inside. Take door panel off and examine. Look for clip in bottom of door. mike1224 05-20-2004, 02:36 AM thanks, i'll check that out red4runner 06-04-2004, 03:59 PM Hey Mike have you solved your door lock problem, I have the same problem, however i can't seem to located where a C clip would go since there doesnt seem to be much room after the cylinder in inside the keyhole. Any help would be appreciated.:banghead: mike1224 06-04-2004, 11:20 PM Yes, I Used Super GLUE, Before you push the lock all the way foward, go around the cylinder. Becareful around the acutal key-hole. I Did this because, I also haven't found a C-Clip (I Was told the part doesn't exist, I have to replace the entire assembly. Hope this helps TopDogg 06-04-2004, 11:57 PM U might not have the C clip. I was thinking of pre 94' models. After the body change they might have changed the hardware. mike1224 06-05-2004, 03:56 PM your right. after about 94-95 they changed the part to an entire assembly. red4runner 06-06-2004, 06:33 PM Mike if you havent solved the door lock assembly yet, hears a good solution, today I got a R6 size rubber O ring and stretched it over the lock assembly, it seated itself just past the chrome cap on the cylinder, push the cylinder through the opening in the door handle and push it in the rest of the way. Works great. let me know how you make out. I took the door handle off the door and worked it in the opening in the handle __________________________________________________ _____________ 2000 chevy s/10 1994 toy 4runner mike1224 06-06-2004, 08:27 PM where can i get the rubber ring at?? red4runner 06-07-2004, 04:50 PM I got my O ring at a local service station or you can get one at peps boys or any auto store the size I used was R6 but you have to stretch it over the cylinder. Let me know how you make out. Automotive Network, Inc., Copyright ©2012
