How to program a remote key Fob?
chamara
05-19-2004, 02:37 AM
Hi !
I have a Nissan Wingroad 2000 model (WFY11).
I did not get the remote key Fob from the seller (for some reason).
now I need to purchase a remote key Fob and program it to the car's existing central locking system.
1. Can I do this?
2. How to program the Key Fob?
Thanks In Advance !
Chamara
Barry#1
11-10-2004, 07:48 PM
Hi,
I ordered a new ebay key blank for my 02 Maxima. How do I program it?
Thanks
ebacon
06-17-2005, 03:15 PM
does anyone have the instuctions for programming the remote? I have a 05 altima
Steve Thiles
07-07-2005, 05:32 PM
Looking For Info On Programming A Key Fob For A 2003 Chevy 1500 PU. I Have Info On Doing This If The Doors Have Electric Push Buttons But Not For The Slide Type Locks Which I Have???
FixUrNissan
10-23-2005, 12:58 PM
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try. Good Luck :)
Steve Thiles
10-23-2005, 06:27 PM
Thanks But I Have A Aftermarket Key Fob By Silencer According To The Chevy Dealer. Also Its A 2003 Silverado Not A Nissan.
FixUrNissan
10-24-2005, 06:54 AM
Then why are you in the Nissan Forum trying to fix your Chevy?
tg64
11-11-2005, 10:29 AM
Keyless remote programing 2000 Pathfinder. Help!! My keyless remote stopped working, replaced battery, but it did not help. I tried reprograming for instructions I had gotten off of internet. Strange thing about doing this is as follows: After getting in vehicle, locking doors, inserting key in ignition (6) times, my hazard lights flash without hitting the remote button. I turn key to ACC position and try pushing button on remote. Still not working. Any advice would be great, the frustration is getting to me. I might go ballistic.
jjw
11-18-2005, 02:48 AM
Can I programing my Infiniti Qx4 remote by the Nissan's instruction.
nel5150
11-18-2005, 10:55 PM
Any luck with this problem? I am having the exact same problem with my 2001 Maxima. Everything goes according to directions until I insert the key and turn to ACC and push the lock button on the remote to program it. I get no hazard flash indication for the successful programming of the remote.
jjw
11-22-2005, 12:30 AM
It's working good in my Infiniti QX4
turn the key to On positon not to ACC, then press remote and the hazard flash will light
ittefaq
11-22-2005, 10:50 AM
Is there anyway that I can program an actual key and not the key fob for an '03 Maxima.
FixUrNissan
11-23-2005, 10:24 PM
Sorry there is no trick i can share when it comes to keys..If you want to program the Key, your going to have to take it to the dealer, The Scan tool has to be used to program that. Also bring "ALL" your keys , any key you don't bring will no longer work
FixUrNissan
11-23-2005, 10:27 PM
Yes Infiniti works teh same , just getting the right patter in and out of ingition is the tricky part
ittefaq
11-24-2005, 01:06 PM
Thanks anyways, I guess I will have to go to the dealer now.
2octops
12-03-2005, 02:40 AM
Most locksmiths that do a lot of automotive work also have the equipment to program these keys. We used to have to purchase the dealer tools for this, but in the past 4 or 5 years, there have been a lot of advancements. Now there are several handheld tools on the market that will program keys to most of the vehicles on the road today.
blakinc
12-19-2005, 03:38 AM
Don't go to a dealer until you contacted a locksmith. I being a licensed locksmith hate to see you guys blow excessive amounts of dough without checking out your options. If you don't know of a local locksmith who can program your remotes or keys, email me brian@blakinc.com and I'll find one for you.
Brent1025
08-05-2006, 04:36 PM
I am looking for programming of a key fob for an 03 silverado 1500 wiht push button locks
Brent1025
08-08-2006, 02:00 PM
[quote=Brent1025]I am looking for programming of a key fob for an 03 silverado 1500 with push button locks. thank you/quote]
teammetal
08-23-2006, 12:03 PM
Does anyone know how to program my remote for my 2003 chevy express 3500 van? Thanks
Sarahbearah
09-27-2006, 11:29 AM
Try this site. They have instructions for most vehicles.
http://www.programyourremote.com/
2006 Volvo S40
01-02-2007, 01:08 PM
hello
i just got a new fob for my 2006 volvo s40 does anyone know how to program it??
please email
the_brav@yahoo.com
thanks
mtpromises
02-05-2009, 01:41 PM
I have a 2005 Buick Lacrosse. I need to program a key fob to the car, How do I do this?
Thanks
lacava5
02-20-2009, 12:54 AM
Does anyone know how to program a remote for a 2003 Dodge Viper or any other 2003 Dodge?
ectpm
04-03-2009, 02:54 AM
Hey I have a nissan xterra 2000 will all nissan oem remotes work on all compatible nissans? and on mine will the trunk button work? does this also work as an alarm, because i opened my back door (suv trunk) and it was beeping at me. Any info I should know about this paticular model/recalls? I just bought this so anything will be grateful.
Jroumell
04-03-2009, 10:06 PM
I need the programming instructions for the remote on my 2005 Chev trailblazer. Part GM15008008. Can anyone help me out?
suzuky23
09-14-2009, 11:54 PM
Re Re 05 nissan altima Key fob!!! Wow Thank's For The Tip I Just Did it Took Me Just 3 Minutes , Super Easy !!!!!! Thank's Again !!!:smile:
InfinityLady
10-07-2009, 08:07 PM
I just replaced the battery for my remote and I have tried the this programming procedure a few times for my 2001 QX4...I get through the in and out of the ignition and the hazards flash...However, nothing happens after I insert the key into the ignition and turn onto ACC or the ON position and then press a button on the remote...I believe the hazards are supposed to flash at that point...But they do not and the remote does not work to open the doors...Is there anything else i can try?....How would i know if it is the remote I have to replace?
Abu Dawood
10-23-2009, 07:29 AM
Any ideas on how to programme a fob for Nissan Almera Tino? I've tried the following but it didn't work.
Unlock all doors, insert key into ignition, turn key from 0 to on 6 times within 10 seconds, waited 2 seconds for lights to flash, pressed lock button 3 times while holding onto unlock button...after that I've had no response.
Please let me know if you have a possible answer.
Thanks
jonathan 11
02-20-2010, 08:32 PM
I need to program my key remote for my 97 Maxima. The only problem is i had to change my ignition key due to a car theft. Is there a way to re program the remote even though i changed the ignition key? I followed the steps of locking the doors and then inserting the key into the ignition and removing it quickly 6 to 10 times but my hazards never flashed so i could not repeat the other steps.can anyone help me with my problem?
Audigrl
03-11-2010, 04:43 AM
does any one know how to reprogram a remote key for a 1998 audi a4 quatto??? it seemed like the battery was dying cuz i would hit the lock button on the remote and it would some times work an then stopped working all together. i replaced the battery in my remote but it still wont unlock/lock my car with my remote. PLEASE HELP!
rlarson
04-10-2010, 02:38 PM
This worked on my 2000 maxima
IMPORTANT: Before entering programming mode, have in possession all of the transmitters you will be using on the vehicle. Once you program the transmitter, all previous codes will be erased from the memory. The other transmitters will not be functional until you program the transmitters again.
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door.
SHAWN KOBUKE
04-23-2010, 04:14 PM
Thanks for the great info!
I was able to reprogram my remote in one try! My husband thinks I'm a genius!
carl.odle
12-23-2011, 12:45 PM
I have a 2010 Nissan Altima and a pocket full of keys plus a fob for starting/entering vehical/etc.
Could I buy a key with a embedded transponder that could be programmed to allow me the same results and give me some room in my pocket again??
Thanks for any help provided...
carl.odle
01-04-2012, 11:47 AM
carl.odle
1-4-2012, 11:50 AM
