Water pump Ford Rangerkaraboo 05-18-2004, 11:34 PM I have had my 93 Ford Ranger (3.0 6 cylinder) for six years, the past two days it starts leaking what I thought was coolant from the radiator not so. The lead is directly behind the radiator and belts, is this a water pump problem? The gages are reading normal level for everything. It leaks after I drive it, and then stops. This morning it gushed out water or something. Can anyone help me out? Thanks. splashiod 05-19-2004, 12:30 PM When you say behind the rad & belts, I assume you mean the front of the engine? If so, that's the water pump. They make a small hole in them to leak & let you know when they're going bad. With the engine cool open the rad cap, start the engine, let it warm up & see if the water is flowing when the thermastat opens. Also look to see if it leaking from around the thermastat(where the top rad hose connects to the engine)Good Luck!! Automotive Network, Inc., Copyright ©2012
