transmission service
lodownlv
05-18-2004, 09:56 PM
hello i was wondering if i could preform the transmission service my self i have a rx 300 and the fluid is looking cind of black. I currently have 60k on it. let mek know what i have to to in detail and if i have to run genuine toyota atf type t-iv on it.
thanks
Justin
92gsr200k
08-24-2004, 12:31 AM
I see you posted a while ago, so would think you either did the change already, or had a shop do it. Yes, you can change the fluid yourself. The drain plug is right below the transmission and there is no filter. Just drain and fill. Of course, just draining won't get all the transmission fluid out, but it's better than nothing. Fill back up with the Toyota type-IV fluid only. Don't use the Dexron III or anything like that.
Good luck.
lodownlv
08-29-2004, 04:29 PM
well their is a filter i changed it and i am also usings dextron atf fluid
plrod
06-02-2005, 01:24 AM
I just found the filter tonight as well; ok to use Dexron but make sure you add an additive to make it compatible with the Toyota spec fluid. I'm thinking of installing an aux tranny cooler since it's so hot where I live. Anyone doing this? Where did you mount it?
lodownlv
06-02-2005, 09:11 AM
dont run additive's at all! and you dont need a tranny cooler it already has one and is efficient even here in vegas. use this fluid and no other your talking to a toyota tech here. and i dont even use their fluids but do use factory filters expecially the oil filter!http://www.valvoline.com/pages/products/product_detail.asp?product=64
lodownlv
06-02-2005, 09:12 AM
dont run additive's at all! and you dont need a tranny cooler it already has one and is efficient even here in vegas. use this fluid and no other your talking to a toyota tech now. and i dont even use their fluids but do use factory filters expecially the oil filter!http://www.valvoline.com/pages/products/product_detail.asp?product=64
plrod
06-02-2005, 10:44 PM
regarding the aux cooler: are you referring to the cooler that goes through the radiator or is the cooler in the passenger side front fender also a tranny fluid cooler?
so you are saying that the Valvoline Dexron product is the fluid to use?
I was referring to this additive: http://www.lubegard.com/automotive/trans_atf_platinum.html
lodownlv
06-04-2005, 06:29 AM
the one that goes through the radiator is the one im talking about. rember you dont want the trany fluid to be too cool. again no addditive's. and dont mess with the tranny they are strong and dont need to be played with. pluss if lex/toy dont make it for that car its not ment to be put on it. its a lexus rember! and yes valvoline dextron III atf is verry good stuff and if you would add any additives i recomend redline but that is usualy for manual tranys for loud chattering
trans
08-22-2005, 03:11 PM
i have a 99 lexus rx300. transmission will not shift into overdrive, even after a new internal kit has been installed. inside is now new. fluid has turned black again. any sugestions as to the cause
