Specslilmx-3w 05-17-2004, 02:59 PM Does anyone know where i could find the specs on the bpT motor for the mx-3.... babybluemx3 05-20-2004, 11:04 AM BP TURBO GTX SPEC 1.8 liter Turbo engine: Type: BP-ZET Displacement: 1839cc Cylinders: 4 Valvetrain: DOHC 16 valve Horsepower: 176 @ 6000rpm (207 @ 6000rpm for #26 block) Torque: 172 lbs/ft @ 3000rpm (180lbs/ft @ 4500rpm for # 26 block) Bore & Stroke: 83 x 85mm Compression Ratio: 8.2:1 Induction Type: Turbo Redline: 6500rpm Alternator output: unknown Ignition Type: single electronic coil, distributor Fuel system: Multipoint EFI Manual Transmission type: G5MX-R (w/viscous coupling center differential) BPTURBO GTR SPEC 1.8 liter Turbo engine: Type: BP-ZET Displacement: 1839cc Cylinders: 4 Valvetrain: DOHC 16 valve Horsepower: 207 @ 6000rpm Torque: 180lbs/ft @ 4500rpm Bore & Stroke: 83 x 85mm Compression Ratio: 8.2:1 Induction Type: Turbo Redline: 6500rpm Alternator output: unknown Ignition Type: single electronic coil, distributor Fuel system: Multipoint EFI Manual Transmission type: G5MX-R (w/viscous coupling center differential) lilmx-3w 05-20-2004, 02:50 PM Does The Bpturbo Gtr Come With A Tranny Or Will It Use The Orginial? babybluemx3 05-20-2004, 02:53 PM not sure about that one..i know one of my freind who owns a gtx is using a protege tranny (don't know what year either)..I don't have more details..I've never done some research on the 4 cyl. bpt lilmx-3w 05-20-2004, 02:55 PM how much does the BTP GSR run? babybluemx3 05-21-2004, 01:46 PM what is a bpt gsr..first time I hear that Automotive Network, Inc., Copyright ©2012
