Can't find horn, need to replace...
Abductee
05-17-2004, 02:33 PM
Does anyone know where the actual horn is located under the hood in a '94 olds cutlass supreme??
I need to replace mine and I'm hoping I can do it myself if I could just find the damn thing!:)
thanks so much!
Slade901
05-17-2004, 04:50 PM
I'm not sure with your vehicle, but mostly the hord is located on the side where the battery is located.
You have to remove the battery and if you have windshield washer reservoir near the battery then you have to remove that as well.
There is a black plastic covering the horn and it you can easily remove it to expose the horn.
Abductee
05-17-2004, 04:53 PM
so is it under the battery then? is that why i have to remove it? or can you explain why i have to remove the battery...im just about to try it...
thanks so much!:)
Sackum
05-29-2004, 02:31 AM
You may want to check between the grill and the rad, most horns I have worked on have been in that general area.
