Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 05-16-2004, 04:49 PM   #1
tigger81
tigger81 Normal reputation
90 lumina fuel pump
The fuel pump is not getting any power. I want to find out if there is anything that can cause this before I go and buy a new one. I have already ruled out the fuel filter, the fuse, and the relay. What else could cause this?
tigger81 is offline   Reply With Quote
Old 05-16-2004, 08:38 PM   #2
broughy84
broughy84's Avatar
broughy84 Normal reputation
Track the wiring down, you could have a broken wire....
Have you checked your fusible Links???
Matthew Brough
1998 Chevrolet Venture -- 104,000 miles
1988 Chevrolet Silverado -- 156,000 miles
1996 Chevrolet Cheyenne -- 107,000 miles
My 96 and 88 before the resto.
My 88 after the Restoration.
broughy84 is offline   Reply With Quote
Old 05-16-2004, 11:15 PM   #3
tigger81
Re: 90 lumina fuel pump
If I do have to replace the fuel pump, is there a panel ? I took out the backseat and looked under the carpet, but could'nt find one.
Old 05-17-2004, 05:16 AM   #4
pcv
pcv Normal reputation
The fuel pump gets power only for two seconds when the ignition is turned on, but there should be power there when cranking the vehicle. Did you check for power with someone else cranking the vehicle? If there is no power to the fuel pump, which is in the gas tank, there is no point in replacing the pump. Establish power to the pump first.
If it is the pump, you need to drop the gas tank down.
Good luck.
NOTHING LIKE AN OLD CAR.
pcv is offline   Reply With Quote
Bookmarks
Google
Web AF
