Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 05-16-2004, 12:57 PM   #1
1sickRamAir
1sickRamAir Normal reputation
Send a message via Yahoo to 1sickRamAir
Car Does Not Start
Hi, I have a 2001 Pontiac Grand Am Ram Air. It has 58,000 miles, no remote start device,but is equipped with keyless entry. The service engine soon light came on about a week ago, and i didnt have time to check it out. My wife went out to start it on morning and all it does is crank over, every now and then it tries to fire but ends up just dying....i changed the spark plugs and wires, maf sensor, checked injectors and pump, left key on for 15 minutes still nothing..if the car would run i would take it to someone,,so any help would be greatly appreciated..
1sickRamAir is offline   Reply With Quote
Old 05-16-2004, 01:50 PM   #2
fluffybunny
fluffybunny Normal reputation
Send a message via AIM to fluffybunny
Re: Car Does Not Start
V6 right? are you sure you have good fuel pressure? try to release the fuel pressure by pushing in the schrader valve on the fuel line then turn the key on and check the schrader again. if youve got good fuel pressure then, have your icm checked out, its at the back of the intake manifold under the coils i believe........ good luck
fluffybunny is offline   Reply With Quote
Old 05-16-2004, 06:32 PM   #3
1sickRamAir
yeah it is the 3.4V6. I checked the fuel pressure with a gauge and it reads 57lbs and the coil pack is firing all the spark plugs..
Old 05-16-2004, 08:25 PM   #4
fluffybunny
its not backfiring is it? only other things i can think of are injectors, timing and compression. if youre sure the plugs are firing, and so long as the injectors are pulsing you should fire lest your out of time, and i havent heard of anyone losing their timing on a 3.4, sorry wish i could help more.
Old 05-16-2004, 11:07 PM   #5
Slade901
Slade901's Avatar
Slade901 0
Try removing the intake hose and expose the throttle body and spray some starting fluid and try to crank the engine and see if the engine stays for a few seconds until it consumes the starting fluid.
If the engine does stay running for few seconds when using a starting fluid then the problem is fuel related.
Fuel injectors might not be opening properly. Possible culprit would be the CTS (Coolant Temperature Sensor).
Normal working CTS, will give the right temperature signal to the Computer and the Computer will in turn will let the fuel injector open longer for the initial start up.
If the bad CTS tells the computer that it is has a very high temp then the fuel injectors might not open longer at startup and so it won't start at all.
1999 Dodge Truck RAM 1500 1/2 ton 4WD V8 360 Z 5.9L SFI QUAD CAB Sport Ed
1999 HONDA TRUCK PASSPORT 4WD V6 03165 3.2L MFI
1997 MERCURY SABLE 6 Cylinders 182 U 3.0L SFI
1994 PONTIAC GRAND AM L4 138 3 2.3L MFI SOHC QUAD
1990 OLDSMOBILE CUTLASS V6 191 T 3.1L MFI
1981 MERCEDES BENZ 240D 4 Cylinders 02399 2.4L DIESEL
Slade901 is offline   Reply With Quote
Old 05-17-2004, 08:01 AM   #6
ponchonutty
ponchonutty's Avatar
ponchonutty Normal reputation
Did you have the ignition switch recall done yet?
ponchonutty is offline   Reply With Quote
Old 05-19-2004, 07:46 PM   #7
1sickRamAir
ended up being the CTS(coolant tempature sensor)thanks for all the advice, maybe someone will have the same problem and read this....and no the dealer told me the only recall available right now is the turn signa emergency flasher recall....
Old 05-20-2004, 12:21 AM   #8
Slade901
Slade901's Avatar
Slade901 0
what the CTS cleaned first and tested, or was just replaced it immediately?
Old 05-20-2004, 07:39 PM   #9
1sickRamAir
i really dont know. I had it towed to a shop, the guy said he had seen the CTS act up in alot of the new grand am, aleros and malibus......i was just glad its fixed
Old 05-30-2005, 01:46 PM   #10
pauluk2w
pauluk2w Normal reputation
Re: Re: Car Does Not Start
I have the same problem on my 1999 grand am I travelled home from work in it (2 hour drive) parked it on my drive, and has not statred since.
the engine turns over and on rare occasion fires up but splutters and dies. any ideas??
pauluk2w is offline   Reply With Quote
Old 05-30-2005, 07:24 PM   #11
1sickRamAir
Re: Re: Re: Car Does Not Start
does it actually start up? or just act like it almost is going to start?
Bookmarks
Google
Web AF
