95 SL2 Idle jumping aroundaliraza 05-13-2004, 04:22 PM Hello guys... I m new here. Wanted to ask you about one of the problem that I am facing. My SL2 1995 has the idle problem. The idle jumps around like crazy. Sometimes it reaches 3000rpm and then sometiems it drops to the point where it just dies. These days I am driving it with my both legs and both arms... Here is the thing... If I am stopped at a stop light, and holding the breaks, the idle remains at 1000 rpm and then all of a sudden it dropped and car stopped. Sometimes it started at a first crank but sometimes needed more than one crank to start. Now what I have started to do is to get it in neutral everytime I have to stop. Hold the break with my left foot and keep the rpm over 1500 to keep teh engine running as I dont want to be stranded in teh middle of the road. The check Engine light is on... I checked the code and its code 26 that is for some kind of quad sensor. Also another code for knock sensor too. What do I need to do. Is it the EGR do I need to change teh knock sensor (Where is it located?) Is there anything else that needs to be fixed. The engine has 65000 miles on it. i will appreciate any help in this regard. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
