Door panels and door locks
Google
Web AF
Titan4
05-13-2004, 02:39 PM
I have a '95 Riviera and I was hoping someone could give me some info on removing the interior door panels. A while back my driver's side door lock quit functioning electrically. I could hear the solenoid moving and also see the lock handle trying to move, but that was as far as it would go. I tried removing the door panel by backing out all the screws I could find, but could never get the panel off. I ended up manually cycling the door lock several times and reinstalling all of the screws in the panel. I have never had trouble with the driver's side door lock since. Now the same thing is happening on the passenger side. The solenoid (actuator) is moving, but the lock handle itself just barely moves. I have manually cycled it many times, but it still will not work electrically.
I want to take a look at the linkage, etc., but need some help seeing how the door panels come off.
While I am here I will add that I have what sounds like a loose screw somewhere under the center console near the automatic transmission shifter handle. I hear the screw roll around when turning and braking. I would like to remove the console to get the loose screw or whatever it is so if you can tell me how that comes off that too would be appreciated.
Titan4
05-13-2004, 03:01 PM
After submitting that post I found a thread on Camlifter's site that appears to have the answer (http://www.regalgs.org/forum/viewtopic.php?t=12750). Thanks for the link Camlifter.
Titan4
05-14-2004, 09:32 AM
Still looking for info on how to remove the center console though. I removed all the screws I can find, but it still does not want to come out.
allfalldown
07-13-2007, 05:49 PM
I removed most of my console myself. Gently pry the trim off over the shifter and most all of it starts coming off, no screws except a few for the cubby.
I stopped at the ash try because I didn't need to go further - but it is simpler than it looks.
Good luck.
Google
Web AF
