Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > GMC > Yukon
Old 05-12-2004, 09:41 PM   #1
dumbfix
dumbfix Normal reputation
door pad removal
2000 yukon needs door pad removed . Heelp! Fast!!
dumbfix is offline   Reply With Quote
Old 05-13-2004, 06:55 PM   #2
GMCTech
GMCTech Normal reputation
Easy, easy, easy!!
remove the door lock bezel, the door handle bezel. and the small piece of corner trim by the upper front corner of the door panel.
Pry easily on the door lock control panel, unplug all electrical connectors (if any).
There are two screws to remove - either both under door pull or one under door pull and one behind the door lock pad that you just removed. _ Should be 7mm heads.
Lift up on entire door panel, and unhook from door - don't pull away yet. - Reach down and pull door light out of bottom of door. and disconnect the door speaker (if equipped).
VOILA!!
Hope this helps.
GMCTech is offline   Reply With Quote
Bookmarks
Google
Web AF
