Cat ConverterSchwein 05-12-2004, 02:50 PM I recently had a test ran on my cat, and it showed it as being totally worn out, the honeycombs inside are busted out. I dont know alot about cat converters, but would this problem with my cat cause my truck to run lean? and loose power? my truck is a 95 s10 5 speed man. 4.3 vorted with 4wd korndogg 05-12-2004, 04:15 PM Does a blueish white smoke come out of your tailpipe when you start it? Schwein 05-12-2004, 11:36 PM not that i have noticed, its been clean.... but ive noticed a loss in power. i have a special exhaust done, i have it coming off a straight pipe to my muffler, and i have my muffler moved up closer to the engine and the exhause tips coming out in front of the passanger side rear tire, its pretty loud, korndogg 05-12-2004, 11:42 PM cause what happened to mine is that i blew the intake gasket and that eventually breaks down the honeycomb. that was on my 93. Schwein 05-12-2004, 11:51 PM so is blowing your intake gasket expensive?,, and does that cause you to loose engine power, cuz in my mind, the honeycomb of the cat is what helps give the engine backpressure which in turn gives you power? am i wrong in saying so? korndogg 05-12-2004, 11:57 PM there is a coating on the honeycomb that turns bad gasses into harmless ones. thats why if your honeycomb is shot, you fail emissions. and the actual gasket is not expensive, i dont know how much labor would be for that either but labor is never cheap. korndogg 05-12-2004, 11:58 PM korndogg 05-13-2004, 12:15 AM it could also be ur head gasket. that may be why ur losin power. your compression may not be all that great cause fluid is gettin in where it shouldnt. Schwein 05-13-2004, 12:24 AM eeh the head gasket word get it away... Schwein 05-13-2004, 12:26 AM head gaskets are bad.. well when they leak they are but i hope to god it isn;t Schwein 05-13-2004, 12:28 AM ill get my compression checked korndogg 05-13-2004, 01:07 AM yeah. that would be a good idea. head gaskets on the 4.3's arent bad cause theres a decent amount of room to work with. well on my truck anyway. i wish all engines were like the old small blocks with a huge area to work in. like my 68 camaro. :) Schwein 05-13-2004, 11:48 AM yea i mean i agree that the 4.3 is more forgiving to work on space wise, my friend has a 2.2 and its tight. do you know about how much a new head gasket would run just for the part korndogg 05-13-2004, 12:00 PM just for the gaskets or the gasket sets? korndogg 05-13-2004, 12:04 PM just the head gaskets would be around 20 bucks and a gasket set is like 60 -80 depending on what u get. just look online at car parts stores and ull get a more precise price. Schwein 05-13-2004, 12:18 PM see i mean admit it parts are cheap, its labor thats killer but i guess everyone has to make a living somehow or another Schwein 05-13-2004, 12:20 PM before i start getting into engine compression and the engine, ill get it tuned up and get that cat replaced. and my serpentine belt is cracked pretty bad. so ill get my cat replaced tune my truck up replace the serpentine belt, and get my pitman and idler arm fixed, it might be a combination of all these things that are making me think im loosing performance, what do you think korndogg 05-13-2004, 12:21 PM dont leave that new cat in there too long with the gasket not fixed cause the same thing will happen. only quick this time and the warranty is voided if you dont fix that. :) Schwein 05-13-2004, 12:28 PM well what if it isn't even the gasket what if its just that combination of things? Schwein 05-13-2004, 12:30 PM this might be one of those things where i pay my mechanic buddy 50 bucks and he checks my compression and gives my truck a total head to toe inspection korndogg 05-13-2004, 12:43 PM well yea.. i would get it checked first before u pay tons of labor charges. like we always tell customers at the shop. start with the cheapest and work your way up. Schwein 05-13-2004, 12:58 PM yea well ill keep you posted on what i find out, im hoping to get this all figured out come summer time i have to much on my plate at one time to get done korndogg 05-13-2004, 12:59 PM yeah lemme know what happens Automotive Network, Inc., Copyright ©2012
