Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Cars in General > Tires and Wheels
Old 05-11-2004, 05:12 PM   #1
Chen
Chen's Avatar
Chen Normal reputation
Angry Control arm bushings
Hey guys, is there any alternative to using a hydraulic press when removing control arm bushings?
Chen is offline   Reply With Quote
Old 05-11-2004, 05:47 PM   #2
BullShifter
SPEED World Challenge GT
BullShifter's Avatar
BullShifter Normal reputation
Re: Control arm bushings
Yes. Press is the easiest.
Without a press, heat/melt inner bushing until it falls out. Then cut through the outside sleeve with a hacksaw or even dremel with cutting wheel.
WORLD CHALLENGE
FOR SALE
She never said anything about finishing quick at the track.
AKA - jackasssi
**My pics**
BullShifter is offline   Reply With Quote
Old 05-11-2004, 06:01 PM   #3
Chen
Chen's Avatar
thanks jack, I'm probly gonna try the poor man's way first and then proceed from there.
Old 05-11-2004, 06:08 PM   #4
BullShifter
I have a website in my favorites at home that has a step by step instructions. I'll post it when I get home some time tonight.
If you have to repalce the bolts, either get them from honda or get HIGH GRADE. Do not use some $0.25 bolts from the hardware store. Suspension bolts are very strong.
www.hondaautomotiveparts.com will have the cheapest prices. I worked for a Honda dealer & that website sells cheaper than I get with my discount at the old dealer.
WORLD CHALLENGE
FOR SALE
AKA - jackasssi
**My pics**
Old 05-11-2004, 06:11 PM   #5
Chen
Chen's Avatar
I got bolts from the junkyard that seem to be in good condition besides being dirty and looking used. Should I go with new ones?
Old 05-11-2004, 07:37 PM   #6
BullShifter
If they are the correct bolts & not cracked, stripped, or broken you should be fine. Those bolts are like $6.00 EACH.
http://www.suspension.com/tips.htm
WORLD CHALLENGE
FOR SALE
AKA - jackasssi
**My pics**
Old 05-12-2004, 12:56 AM   #7
Chen
Chen's Avatar
Dude I am having a hell of a time getting those sleeves out! I broke two scredrivers already. I tried taking the control arm off but I can't get the ball joint apart. (ball joint is right behind the brake disc?) If I can get the arm off then I'll see if it helps me get the sleeves out, otherwise I'll look into taking the arms to a shop.
Old 05-12-2004, 01:46 AM   #8
jcrx
jcrx 0
Send a message via AIM to jcrx
Dude, I can believe your trying to do that with the LCA on the car. Get a ball joint puller, pop it off, and do this... Get a socket set, and find a table vise. Place socket one size bigger on one side of LCA around sleeve, then place a socket the same size as sleeve on hte other, now put this in hte vise and pop it out. Reverse process to install.
jcrx is offline   Reply With Quote
Old 05-12-2004, 02:48 AM   #9
BullShifter
Back down the nut to then end of threads & smack with hammer, that should seperate ball joint or even hit the control arm near the joint. The shock from the hit pops it loose.
Your not gonna be able to pry the outer sleeves out without first cutting it.
WORLD CHALLENGE
FOR SALE
AKA - jackasssi
**My pics**
Bookmarks
Google
Web AF
