Cluster?kenfore44 05-11-2004, 10:01 AM I recently bought a 2001 gmc yukon slt. While driving, the instrument cluster flashes all warning lights then stops, doing this several times. Then, I lose gauge readings. The dealer says I need a new cluster, does this sound correct? What is the cluster and would this be easy to replace by myself? I appreciate the advice. tobyw 05-11-2004, 12:04 PM I can't tell you for certain if it needs replaced, but it is easy to do. He's refering to the instrument cluster, where all your gauges are. It's a one-piece electronic unit. Several places sell used instrument clusters for anywhere from $80-$300. Check Ebay, and maybe do a search on this forum for tons of info. To replace it, you simply pop off the dash bezel, remove 4 screws that hold the cluster in place, unclip the wiring harness from the back, and then reverse the process to install the new one. 15 minutes, tops. Automotive Network, Inc., Copyright ©2012
