supercharger problem plz help
laoz_gsr98
05-08-2004, 09:51 PM
hey im installin my supercharger to my 98 integra gsr and im noticing that it idles really high...does anyone kno how i can fix this problem....??
superbluecivicsi
05-09-2004, 04:52 AM
what type of supercharger?
Is the idle bouncing up and down or is it just stuck at a high idle. where is the idle at? Is your CEL on?
If its bouncing up and down it could be a bad IACV. But since you are done with a supercharger install, make sure you have no vacuum leaks............solution---------> pull out the iacv and check for a torn screen or blockage. If its not that, then make sure the vacuum lines are tight and there are no cracks, cuts, or any kind of leaks in them.
If the idle is high and just stays high, then check the gas cable line to see if it is too tight. It could also be that the gas pedal is stuck onto something causing a high stuck idle.
laoz_gsr98
05-13-2004, 03:35 PM
thanks alot man...ill check it out
