Transmission Shim
ragnarok720
05-08-2004, 06:54 PM
Does anyone know if there are any companies that make shims for the 02 wrx transmissions?
2turboimports
05-20-2004, 02:08 AM
what's a transmission shim?
ragnarok720
05-20-2004, 07:18 AM
It shims the tranny from the engine block. Like if your flywheel was too fat and you didnt want to hit the shifting fork, you'd shim it to move it away.
2turboimports
05-20-2004, 10:12 AM
that's what i thought, but how would the flywheel hit the shift fork? i'm not understanding why you'd need this.
freakray
05-20-2004, 10:51 AM
Maybe if you're using an after-market flywheel?
2turboimports
05-20-2004, 10:54 AM
i've had a couple of aftermarket flywheels and never haerd of this?
freakray
05-20-2004, 11:36 AM
Neither have I, but I was just throwing an idea out there.
ragnarok720
05-21-2004, 05:16 AM
Yes, aftermarket flywheels. Its an option to do it if you get a flywheel that is too thick which is the case with the 02 wrx and their cutoff dates. Some are 6/2001 and up build dates and the others are 5/2001 and below. Mine was built in 1/2002 so i should have had to used the 6/2001 and up but nooo i have to use the 5/2001 and below flywheel. 02 wrx's are all screwed up. Sad thing is, the difference between the 2 flywheels is 1/8 in thickness.
