Speedo inop intermittantlyirish30 05-08-2004, 06:11 PM I have a 1992 Civic DX. Five speed trans. The speedo will work for awhile then drop to 0. It stays there for awhile then starts operating normally. I have Ford experience but not much Honda. I know that it is electronic not cable, I think I found the speed sensor on the tranny. Is it more likley the speed sensor or a cluster problem? How would you test the speed sensor for proper operation? Is it a hall effect sensor, potentiometer, or what? Thanks in advance for your help. Ricochet 05-08-2004, 08:47 PM Definitly a speedo sensor problem. I replaced the tranny on my friends '91 Si and his speedo didn't work. All I did was tighten the sensor in some more and it worked fine. Check the wiring and tightness of the sensor, shouldn't be too hard to fix. Good luck. Ricochet 05-10-2004, 01:08 AM Have you tried fixing this yet? I want to know what went wrong.. irish30 05-10-2004, 06:31 PM Not yet. I drove the other day and it was working for awhile. Then it stopped. I went to gas station and unplugged the connector on the trans speed sensor and plugged it back in. Drove again and it worked fine again. :screwy: Ricochet 05-10-2004, 06:35 PM Yeah, they are pos's. Expensive pos's though :( Automotive Network, Inc., Copyright ©2012
