92 wagon battery problemwhiteyao 05-08-2004, 02:56 AM I just bought it from a "dealer". 24hrs after I bought it, it worked. But two days later, it had a problem: The engine stopped after a few minutes after idle, and couldnt start it again. Gave it a jumper recharging, it started again, and died again when idle. ( I can run it after it was started) Is there anything consuming the battery quickly or is the battery toast. I am a navie, Thanks for you help. mightymoose_22 05-08-2004, 03:08 AM A few things: Check that the wires at the battery and alternator are tight. When the engine is running, listen under the hood for a hissing sound which will indicate a vacuum leak. You may have a bad ignition switch... Can't think of anything else... Hmm... if you can't figure anything out see if you can get the car to a parts store that will cehck your battery and alternator for free. amature 05-08-2004, 09:20 PM I would check your alternator whiteyao 05-10-2004, 12:36 AM Yes, The wire at the battery went loose. it is ok now. Thanks for your help. Automotive Network, Inc., Copyright ©2012
