bg fuel system cleanerkbarlettafran 05-06-2004, 08:41 PM does anyone know if you can use th BG Fuel system cleaner without the pressurized tool they sell. And if so could you explain it. Someone told me it was a really good product to restore engine performance but didn't say how to use it. thanks fb JoeJoe231455 05-06-2004, 08:56 PM If you want to clean the fuel system purchase BG 44k in a can. You can dump the stuff right into your fuel tank before a fill up and it goes to work over the life of the fuel tank. It is a great product and you should try and use it every 15-20k. There is also BG intake cleaner which is probably what your friend was talking about. You can feed it into the engine through a small vacuum line without the little feeder kit (I think that is what your talking about). Flatrater 05-06-2004, 09:48 PM Joe that is the induction service you are referring to, BG also has a kit to clean the injectors which you need to tap into the fuel rail and run the cleaner in a pressure pot to clean the injectors. Automotive Network, Inc., Copyright ©2012
