1992 Keyless Entery Programming
buickguy
05-06-2004, 05:33 PM
Does anyone know how to program a new key fob for a 92' Roadmaster?
buickguy
05-06-2004, 06:09 PM
After digging around in here, I think I found the answer to my question.
1. In the trunk, on the lesft side find a black plug that goes to nothin. Its just hangin there. you will se a whit stripe on the black wires coming off of it.
2. just stick a small screw driver into the plug making sure that it touches the two small pins inside the plug.
3. holding th screwdriver in the plug you will hear the door locks and/ or trunk lock click.
4. do not remove the screwdriver and when you hear the clicks press one of the buttons on your remote sweetch and you will hear a lock click that means you just activated teh remote....
5. if you have 2 remotes press a button on the 2nd remote switch at this time and you will hear a lcok click meaning that remote will now work too.
6. remove screwdriver and test your remote switches.
I tried this with my car with my original key fob and it worked. I am now going to buy one on ebay and hopefully it works. I read when buying one one ebay, you have to make sure the FCC/ID # matches your original key fob. Search around on ebay. There are some great deals. I will post next week after my new used ebay fob gets here.
OK, got my used key fob off ebay for $12.00 and used the above instructions to program that one and the original one. It took about a minute and they both work great!
