2000 Escort ZX2 stalling
Amerika
05-06-2004, 01:18 PM
I have a 2000 Escort ZX2 stick shift with about 40k miles on it. WHenever I have the AC/heat turned on the car stalls when I put in neutral or downshift to first to come to a stop... Occasionally it won't stall but the RPMs will drop to about 250 and the car will try to stall for a minute but then kick back up to 1000 RPMs... It only happens if I have the AC turned on or if I have heat going. Can run cool air fan without AC but not warm air. Had a full tune up, had the fuel filter and pump checked and cleaned...Any ideas?
Thank you.
Jet-Lee
05-06-2004, 01:43 PM
IAC? Idle Air Control...right on top of your throttle body...my guess.....my car does the same thing, but that's part of a WHOLE different issue
zx2srdotnet
check teh air sensor
mightymoose_22
05-08-2004, 02:55 AM
That's odd... not sure why it would only happen when the AC is running. It NEVER happens when you don't have the accessories running?
I would suspect vacuum leak, but the AC thing is a twist. In addition to the things mentioned above, check your alternator output when those things are running. I wonder if the high idle is working...
