Engine problem after wash (engine)xcellauto 05-05-2004, 11:55 PM My 99 Accord 2.3L became very illed the next morning after I gave its engine a good wash down with the garden hose! My engine when started cold seemed to run on all 4 pistons, but shortly after it began to warm up, the third combustion chamber seemed to quick popping. I confirmed my suspicion by pulling the spark-plug wire to that piston + disconnected its fuel injector.... sure enough, no change in idle speed nor rhythm! (Same action to any other piston produced a change). Acceleration hesitates and loss of power. I thought it was the dead plug... changed, but same problem. I thought it was the clogged injector... changed, but still same problem. Anyone has any suggestions? AccordCodger 05-06-2004, 12:34 PM Sounds like water in the HV electrics -- distributor, plug wires. Igovert500 05-06-2004, 07:17 PM Yeah, next time try engine degreaser or steam cleaning. integrasedan 05-06-2004, 08:00 PM just let it sit overnight it should dry by then. 99AccordF23A1 05-12-2004, 10:24 AM yeah, water in the distributor cap. not a very good seal on there usually. same thing happened to my buddy. 99AccordF23A1 05-12-2004, 10:28 AM sorry i didn't see that last reply before i posted my first but letting the engine dry didn't fix it. had to replace the distributor. check the terminals for oxidation and clean em up a little before you replace it. Automotive Network, Inc., Copyright ©2012
