ClikitaclikitaBlackBlur 05-05-2004, 10:18 PM My GS is acting up again. There is this funky clicking noise from under the hood. It seems to be located around my belts, possibly a bad bearing in a pully. Would this make the clicking sound I described? ashah000 05-05-2004, 10:24 PM Check your tension on the belts, then try some dressing guitarXgeek 05-05-2004, 11:18 PM Yea it's probably the tension on the belts like ashah said. I just replaced my power steering belt, and it was clicking for a while until I tightened it up a bit. BoostedSpyder 05-06-2004, 03:42 PM maybey lifter ticking noises BlackBlur 05-06-2004, 03:52 PM maybey lifter ticking noises Thats what my dad said, but how would I find out if thats what it is? I guess i should first check my tension and if that doesnt fix it...... ashah000 05-06-2004, 03:55 PM Thats what my dad said, but how would I find out if thats what it is? I guess i should first check my tension and if that doesnt fix it...... Your EAR :smile: If it is coming from the valvecover then its the lifters, otherwise listen for where its coming from BlackBlur 05-06-2004, 04:06 PM ohh, well thats simple enough. thanks ill go check and post back in a little while. ashah000 05-06-2004, 04:15 PM Do you only hear this when the car is cold and warming up to normal operating temperature BoostedSpyder 05-06-2004, 04:43 PM you can get better oil to reduce lifter tick BlackBlur 05-06-2004, 05:31 PM it happens all the time. warm cold, no matter it always clicks. But is seems to be in rhythm with my belts, which i suppose could still be my lifter though. ashah000 05-06-2004, 05:33 PM Tighten your PS belt, that seems to be the one that causes the most problems BlackBlur 05-06-2004, 05:41 PM and how might i go about tightening it? ive never messed with belts before...at all. ashah000 05-06-2004, 05:57 PM Automotive Network, Inc., Copyright ©2012
