| Engine intakes, exhaust, turbos, nitrous. |
01-15-2002, 12:26 PM
Cold Air Intake
I am planning to make my own CAI and have a question regarding what size of Mandrel bent piping to use 2.5" or 3"? Could some tell me what size the HS intake is or PRI?
What is the benefit or 2.5" over 3"? Would there be a noticeable difference between the two sizes?
Thanks
Juan
Black 91 G20
slightly modified
"My goal is not to be the Fastest. Only faster than you Mr. Honda owner!
My Website
01-15-2002, 02:49 PM
the Hotshot CAI is a 3" diameter, i would go with a 3" diameter because the TB is close to 3" than 2.5". id assume the 3" pipe gets more air, but could offer more resistance. 2.5" might be more free-flowing.
01-15-2002, 03:44 PM
The different sizes of intakes doesn't really have anything to do with resistance, it has to do with smooth/laminar flow of air. It also has to do with what RPM will be best for the given size of tubing. You get better power when your intake and exhaust are free of restriction. However, if the pipe is too large the air swirls around inside because it doesn't have enough force to keep smoothly flowing. So, smaller diameter tubing is better at low revs because the relatively low volume of air moving through the system can flow smoothly without restriction. Large diameter is better at higher revs because the larger volume of air requires more space in order to flow freely. That's why a 3" diameter exhaust will give you more top end but at the expense of low to midrange and a 2"-2.5" exhaust will give you better power down low but will not be able to breathe well in the high revs. That's also why most stock 4 cylinder cars have very tiny exhaust systems. The manufacturers know that the average driver will get more use out of 5 extra HP at 3KRPM than 15HP at 7500RPM. If you want top end horsepower i'd go with the 3". If you want more low-end, usable power (but less of it) i'd go with the 2.5".
Why don't you get ahold of a dyno chart for the HotShot CAI and see if the gains are what you want. If so, try to copy their design. Or, just save yourself the hassle and cough up the money for the real thing.
-Grant
1999 Infiniti G20t
17" RH Evolution M7000's with Toyo's
Mostly stock...for now.
Klaatu Varata Niktu
01-15-2002, 06:16 PM
-Grant
ya what he said
01-15-2002, 09:10 PM
Originally posted by AznVirus
ya what he said
Uhhhh huh.
Anyone who tells you money is the root of all evil, doesnt f#!@ing have any.
01-16-2002, 03:30 AM
Hey guys, before you go too far on this idea... It's already in the works to test a 2.5" vs. 3" CAI... also every combo of the two intakes, 3" top pipe w/ 2.5" lower pipe, etc.... All the setups are going to be dyno tested and we'll find out what combo works the best for top end power, mid range, low end, etc....
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft  )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
01-16-2002, 09:27 AM
Ive seen some Hunduh intakes that are wide at the end (filter side) maybe 5 to 6 inches and narrow near the back. but thier made out of plastic. Maybe this design is hinting to a better performance at low and high end revs. .
Hey Justin, when will that data be out?? Im thinking of making a custom CAI with the $tillen intake on it
01-16-2002, 09:05 PM
Just buy the intake from JWT--Stillen uses the same intake element...i believe the only difference is the machined Stillen logo...and a few bucks.
1996 P10(E)
17' Enkei RS6
205/40ZR-17 Yoko PARADA
HS ColdAirIntake, w/ bypass valve
GReddy MX Exhaust
Hotshot Headers
JWT S3 Cams
Unorthodox full kit
-anvanced spark plug timing
-JWT ECU
-and always on Premium, at least...heh
01-16-2002, 10:06 PM
I'm hoping to get to the dyno later this month, possibly early in February (only a couple weeks away, month at the longest) when we have our next SERCA dyno day here in Az. I have all the components readily available to me, i'd just need to get to the dyno. I'd also like to wait and do it at the dyno day, as it'd help a lot if i could save a couple dollars on the dyno time, as i'm a poor college student.
Justin McClanahan
95 G20
01-16-2002, 10:45 PM
Most car manufacturers make the inlet to the intake larger than it is at the point it enters the throttle body/carburetor. The reason for this is that it speeds up the air going into the engine. A large amount of air enters the intake and as it gets smaller the air has nowhere to go but into the engine. In order to fit the same amount of air in a smaller space, it has to speed up. This venturi effect increases horsepower.
...or something like that.
1999 Infiniti G20t
Klaatu Varata Niktu
01-17-2002, 10:29 AM
I'll really like to see the dyno results between the Home made and other CAI's.. Please keep us posted.
Juan
Black 91 G20
slightly modified
My Website
01-17-2002, 08:50 PM
I really would like to see the difference between made by the size of piple, good idea justin
02-14-2002, 05:19 AM
Justin-
Did the data come back yet?
I didn't even know you were collecting info that the dyno day for that kinda stuff.
sweeeeet!
-clifford
02-14-2002, 07:41 AM
Actually, the opposite of that. When it goes from larger to smaller, the air slows down.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
02-14-2002, 03:07 PM
No, George, i believe you are incorrect.
A certain volume of air is already in the tube. If the tube gets smaller, the air has nowhere to go but through it. In order to fit the same (large) volume of air through a smaller space, the air must speed up. This effect is used often in air intakes.
I'd dig up my book on this subject and quote it, but i'm leaving for California tonight and won't have time. If i remember i'll try to post some references when i get back from CA on the 20th.
1999 Infiniti G20t
Klaatu Varata Niktu
