GReddy Turbo & Intercooler Kit FOR SALE- BELOW WHOLSALEcivic2457 05-04-2004, 10:22 PM Complete Greddy turbo and intercooler kit for d16 $2100 SHIPPED. Let me know Thanks. Also have BOVand GReddy turbo timer brand new if your interested. Ordered the turbo, then did an h22 swap. I never installed the turbo, still in Greddy packaging never opened. BLU CIVIC 05-04-2004, 10:23 PM sell a whole lot faster if u had pics...oh yeah....i forgot about this..... :useless: civic2457 05-04-2004, 10:50 PM Here's the pic civic2457 05-04-2004, 10:51 PM How Do I Add It? BLU CIVIC 05-04-2004, 11:18 PM i would tell u but i can't add pics for some reason.... TSRyder6 05-05-2004, 10:18 AM Send me the pics at AnswerPride@hotmail.com and i'll post them up... :icon16: TSRyder6 05-06-2004, 04:09 PM ait civic2457 send me the pic so here it is... http://files.dmusic.com/music/b/o/bozzkid/GReddy_Turbo_Kit.JPG o0Quicksilver0o 05-08-2004, 02:31 PM hehe ...looks like it has been opened? id be interested if i could just buy it without the ic. civic2457 05-09-2004, 01:06 AM $1650, shipped, for turbo only. Can giev you turbo timer for an extra $75. pikkagtr 05-12-2004, 09:41 PM the turbo timer is universal correct id buy it for 75 MrCrazy 05-13-2004, 04:09 PM this may sound like a stupid question but, what kind of engine does that fit on again??? Jas_M 05-14-2004, 02:16 PM D16 vtec92civic 05-15-2004, 09:44 AM nice looking kit . . . . SleeperCivic 05-16-2004, 08:43 PM I could be wrong, but that looks like the 18G turbo in that pic. I haven't seen the Greddy badge on the compressor housing in any 15G or 19T kits. Do you have a closeup pic? civic2457 05-16-2004, 10:44 PM Change of plans im going to keep the turbo kit and the d16, what internals will give me the most power, I am keeping it at 6-7 psi, what internals do i need to raise the boost to like 15psi SleeperCivic 05-16-2004, 10:51 PM Change of plans im going to keep the turbo kit and the d16, what internals will give me the most power, I am keeping it at 6-7 psi, what internals do i need to raise the boost to like 15psi For a reliable 15psi you really want to go for pistons and rods. You don't have to have the block bored out, but getting a good hone on the cylinder walls is a must to ensure that your rings seal correctly with your setup. I was quoted at $100 from a local machine shop to do the ring fitment and $140 to hone the block. Also, because the D rods were so skimpy from the factory, a small amount of the inside of the block will have to be ground out to ensure proper rod clearance. For the pistons - stay with stock compression ratio. They're stronger so they won't crack under the same load. Also, the stock CR will keep that "daily driver" feeling. You'll also get faster response from the turbo. I recommend Eagle rods and SRP / Carillo / Ross pistons. There are so many piston makers that it's silly. While you're inside the block, replace the headgasket with an OEM version and drop those head bolts in favour of some ARP studs. Dey B coo, man! Replace the water pump and other necessary gaskets along with rod bearings. DeleriousZ 05-16-2004, 10:53 PM on a d series? if i were you, i'd get the block sleeved as well as new internals.. especially for 15 psi. i'm not sure if weisco and JP and them make pistons for D series, but you could look into it.. you'd most likely want to redo the valvetrain as well SleeperCivic 05-16-2004, 10:54 PM on a d series? if i were you, i'd get the block sleeved I forgot to mention that! Take a look at this link: http://www.exospeed.com/engine/machiningservices.htm Sleeving at very reasonable prices. Too bad AEBS doesn't have the hookup on the D - I'm a dealer for them. :banghead: civic2457 05-16-2004, 11:57 PM How much HP do you think i'll be running then , and the price to do all that? boosted_88_CRX 05-17-2004, 10:53 AM can u sell just the intercooler??? bc i can remake all my charge piping.. vtec92civic 05-17-2004, 01:28 PM Change of plans im going to keep the turbo kit and the d16, what internals will give me the most power, I am keeping it at 6-7 psi, what internals do i need to raise the boost to like 15psi internals that will give you some extra power would be camshaft, but to raise the boost you are going to want: Pistons Rods and some good tuning . . . . . you can also get stuff such as valve, springs, and retainers for the head, but they are not needed or required. Getting your timing right does help with the car running, and performing a lot better. Hope that helps. Automotive Network, Inc., Copyright ©2012
