Re: idle air controller
That doesn't sound like the IAC at all... not to me anyway. Some basic tune-up stuff may go a long way here.
Have you checked the condition of your air filter and your spark plugs? Try running an injector cleaner through the system.
A vacuum leak could cause your stalling, but I am not sure why the car is so hard to start again.... I suppose the IAC could be to blame, but I would suspect that more if the car stalled at idle, not while going down the road. Hmm...
When you start the car for the first time of the day, let it sit and idle for awhile... pop the hood and listen for a hissing sound around the area of the intake manifold or from the hoses on top of the manifold. If you hear one then you have a vacuum leak to fix.
Good luck to you... if you come up with any more info to share pass it along...
