Really Rough Idle.
HondaSpeed
05-03-2004, 08:02 PM
Ok,
I upped the RPM's so it idles higher, and even now I sit at stop lights and the whole car shakes, I mean nothing noticeable from outside the car but you can deffinately feel it inside. You can see the steering wheel shake. It smooth's instantly with a little gas, but it is really annoying. If anybody knows what it could be, and even better how to fix it it would be much appreciated.
jakedubb
05-04-2004, 11:52 AM
Here ya go. This is the best info I have seen to date!http://www.cybertrails.com/~bestinthewest/autotips/9091accordcomprblems.html
cglenn2a
05-06-2004, 05:38 PM
Have a compression test done. If it smooths when you give it some gas you may have a compression problem, ie.. incorrectly adjusted valves or burnt/ damaged valves. Worth a shot
92lx
05-07-2004, 12:37 AM
Depending on the situation, this actually sounds normal for a 4th gen with miles on it. Usually it's just because of soft motor mounts, if you have an auto...that'd be why, hydraulic rear mount relaxes as a stand still sometimes causing the steering wheel and such to vibrate.
- Nathan
dumpedwagon
05-07-2004, 03:01 PM
thats what i was thinking, My 92 wagon seems to have that same problem, thought about getting new motor mounts, Guess I have to do it now
HondaSpeed
05-10-2004, 10:59 PM
Is this the same with the fifth gen's? This prob isn't the end of the world, but I always wonder what effect it might have on other things that could rumble loose over time, or anything like that. It would be a pain to replace the mounts.
Igovert500
05-11-2004, 12:04 AM
How much are new mounts, and how hard are they to install?
dumpedwagon
05-11-2004, 01:51 AM
I would check with local dealer firs but then look on line, i have found many cheap factory parts for my 92 wagon!
jakedubb
05-11-2004, 02:20 AM
Just remember that you get what you pay for! Scimping on mounts isn't a money saver unless they're good quality...
