gsr or rsx basekingpinn 05-03-2004, 01:18 AM what is better in the long run gsr or base rsx i like drag racing by the way and dont say get the type s because i'm only 18 and money is not there for the type s but the base maybe .... what i'm lookin for is bang for the buck......thanks....... mmont0 05-03-2004, 03:49 PM I'm assuming by GSR, you're talking about the older Integra GS-R. If that is the case, here are some stats for you: GS-R(2dr) - 170hp, 128 ft-lbs., max torque @6200 rpm, max HP @7600 rpm, weight - 2572 lbs. Base RSX - 160hp, 141 ft-lbs, max torque @6500 rpm, max HP @6500 rpm, weight - 2694 lbs. The RSX has a little more torque and HP maxes out lower which will get you going quicker, but it does have 10 less HP and weigh a little more. I would probably get the GSR, since it will be cheaper, and with the savings, make mods to get it to perform better - carbon fiber hood, CAI, and possibly a turbo kit. It will probably end up costing you about the same price as an RSX base, but you'll definitely have a much faster car. Hope this helps. crazy_canuck 05-03-2004, 05:39 PM Depends, the GSR is gonna be better for mods right now, the RSX will have potential later on. I'd probably get the GSR, but if it was a Used Type S vs. GSR i'd take the RSX. RSX-S777 05-03-2004, 06:02 PM Easy. GSR. Automotive Network, Inc., Copyright ©2012
