is it cutout on my Jaytona?Pages :
[1]
2
Bowza 05-01-2004, 05:01 AM yo..now that i got my cat removed and a straight threw muffler on my tona...when i slam it to the floor..it gets up to high rpms and it cuts out for a sec..then goes again..i got the 2.5 l and i thought my boost was only suppos to go to 8 psi and a bit of overboost or something..but now my boost goes all teh way up to 12.5/13 ...do you think it is my computer not allowing it to go past the boost limiter?..so it cuts my boost out for a sec..or is it something else... and could someone plz tell me what happens when detonation occurs..i heard all bout it..duno exactly WHAT it does/is...thx guys.. Jaytona Geeko 05-02-2004, 04:55 PM detonation is a *bang bang* sound that means you are killing your engine. to simplify: DETONATION = DEATH also, i wouldn't talk too much about removing your cat, considering that is very illegal. i would, if i were you, look into getting a high-flow cat. if you get stopped for a roadside spot check, and are sans-cat, then you are totally screwed- that's an expensive fine, AND a repair ticket. just a suggestion ;) DaYtOnAt2 05-02-2004, 09:51 PM Don't worry about the cat, I've NEVER been inspected. EVER. It sounds like what's happening is your hittng max boost and after the pre-set time limit it's being reduced to lower cylinder temps for a few seconds.Which will help to prevent detonation. I think it's until you let off the gas a bit. It's all normal stuff your logic module is taking care of. As long as you're at WOT the timer doesn't count down to allow "full" boost again though. There are ways of tricking the map sensor to only "see" the 8psi but still run 14-15 all the time but if you don't have the fuel system to compensate for it don't even think about it! The margin for error is very small when tricking components that normally work in harmony with each other. slantsixness 05-03-2004, 07:49 AM Ok, What did you do with the O2 sensor? I didn't think you did anything. now change it. Remove the air temp sensor in the intake and replace it with a 100K resistor. Check your TPS too, along with almost all of the other sensors. be damn sure your intake air hoses are sealed tightly and that they dont swell or collapse. I recommend replacing then with pipes, but the stupid rubber hoses will work. You NEED more fuel volume and a reprogrammer kit....!!! Or, drum up an old Direct connection turbo II computer from Carrol Shelby... Detonation is bad, but fortunately, you don't have a Civic (not fond'a honda) or an eclipse ( e-clips?!! either way you're shafted!!). Never seen a 2.2 or 2.5 die from detonation. I have seen an eclipse die from daytonation (being wasted by a daytona... mine!). Enough fun for one post... Slantsixness DaYtOnAt2 05-03-2004, 09:49 AM LOL dunno about that resistor though, won't it make him run a little more lean? Good for HP bad for detonation... Yeah I ran tons of boost with a secondary 5th injector right on the limit of the green lights and never had a problem with detonation either. The mains ended up giving in first. That and the hydraulic adjusters couldn't keep up. :mad: Geeko 05-03-2004, 02:10 PM Detonation is bad, but fortunately, you don't have a Civic (not fond'a honda) or an eclipse ( e-clips?!! either way you're shafted!!). Never seen a 2.2 or 2.5 die from detonation. hunh, didn't know that... never got around to FI on any of my dodges so i never had to worry about detonation whassa mattah slant, been whupped by too many small-displacement H bombs? i love my car, i'll probably drive it to death several times over. i like my dodges too, and even my old ford crap-wagon has some fun parts. no reason to go hatin' on something that beat you just because you can... after all, bet you don't mock that 'vette that just passed your ass like you're standing still :cwm27: Bowza 05-03-2004, 02:20 PM hmmm...ok..so my problem doesnt sound like detonation cause my engine aint makin a bang bang..so im guessing it would be my map sensor doing its job. a 3 bar map sensor will eliminate this correct...would a stage 2 calibration from fwdperf. eliminate the problem as well?..i plan on gettin an intercooler before turning boost up to 14 or so thou..so...yea Bowza 05-03-2004, 02:24 PM and do you figure my turbo gage is reading wrong when i reach 12.5 psi when i should only be reading 8 or so?..when i got a flow threw exhaust it seemed to have turned up a bit..oh yea..and you were talkin about my cat stuff..not that it would help me if i got pulled over and inspected, but i got flanges on all my pipes so i can remove straight pipe and put on my original cat pretty simple..im off to school..lata slantsixness 05-03-2004, 03:15 PM Geeko- I don't race anymore, certainly not on the street. The point was it's rare to have a 2.2 or 2.5 die from detonation. You like what you like: I like what I like. What I like is just faster. And I've never been passed by a 'vette like I was standing still, unless I WAS standing still. I'm not in the racing scene/gang/group anymore. I have a wife, daughter and a life, that keeps me from that waste of money. There was a time when I would dispute that to the end of the 1/4, but not anymore. I want to be around for another 40 years... or longer. Slantsixness BleedDodge 05-04-2004, 12:08 AM My 2.2 has seen a couple headgaskets but it's otherwise bulletproof. I don't believe you can kill these 4 cylinder Chrysler motors... slantsixness 05-04-2004, 07:40 AM As a 2.2/2.5L thread this has become, I've had lots of them. Good motors, BAD carburetors. Fuel injection works well. MPF injection is really good. Turbo version aren't bulletproof, they suffer from chryslers "Turbobyebyetis", where the turbine comes unglued and sends all your oil into your intake, but that can be dealt with if you know when to shut the motor down! (like the moment the white smoke comes out... ) Use intercoolers and VNT's or aftermarket turbos and WOW! I had an '87 shelby Charger,'90 daytona ES 3.0L, '90 Daytona ES 2.5L (VNT, intercooled and NOT factory), '79 TC3 (originally a VW 1.8L until the 2.2 turbo drivetrain), a Lebaron GTC, about six K-cars, an Omni 4dr (pre GLHS), and two turbo 2.2 Caravns (one was a 5 speed manual!) These were daily driver cars except the shelby and the '90 daytona. Unfortunately all but the second '90 daytona (the VNT) are gone down the road, and my father in law has the daytona now (his GM car died, kind of funny-he had his mid-life crisis and ended up with his son-in-law's last non-family sedan ride!). I'm looking to maybe squish a 3.5L mitsu motor and two VNT turbos (it will fit...)in another Daytona when my wife let's go of my arm...and some dough! Slantsixness Geeko 05-06-2004, 02:15 PM Geeko- I don't race anymore, certainly not on the street. The point was it's rare to have a 2.2 or 2.5 die from detonation. You like what you like: I like what I like. What I like is just faster. And I've never been passed by a 'vette like I was standing still, unless I WAS standing still. I'm not in the racing scene/gang/group anymore. I have a wife, daughter and a life, that keeps me from that waste of money. There was a time when I would dispute that to the end of the 1/4, but not anymore. I want to be around for another 40 years... or longer. Slantsixness hey, i'm in agreement- i'm on the front of the hill going up, and don't want to spend the rest of my life in a wheelchair, or worse. *shrug* i'm probably overreacting- just sick of people either making fun because i've got a honda and it doesn't have a bunch of body kits and crap, or people making fun because i drive a honda and want to increase its performance. i don't race- at all right now, probably not much if i ever do- and not on the road. i like to drive- and i drive hard. i like it when my car reacts to my desires- a complete melding of man and machine (cliché, i know, but true) brings me happiness. all in all, that's what matters- that you are happy with your ride, and enjoy driving. so run some FI on that teeeeny honda moter, or rev up all 454 cubic inches of that monster under the hood of your charger! ~cheers~ DaYtOnAt2 05-07-2004, 12:22 AM I thought a 454 was a bowtie motor...I get the point though, and agree... Geeko 05-07-2004, 11:37 AM craap... can't believe i did that, my buddy would kill me >.< okay, the 454 under the Camero hood. my dream car is a '69 Supersport, cherry red, black ragtop, with a freshly rebuilt 454 under the hood :D i'm a long way away from that with my civic... but who wants to daily drive a 454 with gas at 2 bucks a gallon? slantsixness 05-08-2004, 08:17 AM I'm an A-body (dart/duster/swinger) man. Although I've had some B-bodies (charger/GTX/Roadrunner etc) but they didn't do as much "warm fuzzy feelings" as a 12 second A-body. Plus, the A-bodies are easier to park...! I originally bought into the fact that the Later charger and daytona's were going to give me that "warm Fuzzy feeling" back, but I had a lot to learn about the 2.2 and 2.5 and even a little about the 3.0(dog). So, in the efforts to make one of these newer FWD cars scream, I've wasted 10 to 15 times the amount of money it costs to make a 12 second (ok, 12.49 @ 104mph.. still call it a 12!) street legal car. I was able to beat the average Z28/iroc camaro's and 5.0 mustang's with the FWD cars, which did give me a warm fuzzy, but I have always been disappoointed with the lack of real recognition the FWD cars get, and even the "muscle car" mopar freaks don't give the FWD cars the recognition they deserve. Sadly, the most interesting thing coming out of the pentastar-benz company now, is either way overpriced (viper), or way underpowered (ptcruiser convertible 2 door). I'm lucky my wife let's me keep what I have. And she has a camry (although it is a V6....) Her first choice was a honda Accord.....! So, I'm not immune to working on, and liking the ricers either, but I still don't think they'll ever give me the warm fuzzy's!! too much time on the soap box! Later, Slantsixness Geeko 05-09-2004, 11:16 AM FWD sucks for performance, i'll agree to that. it's just NOT as much fun as RWD (or AWD, for that matter) in a performance vehicle. no matter how fast you accelerate, or how powerful the car is... it just doesn't feel the same. when i had my '90 Dodge ramvan 250 LE (318 baaaby, wooo) it was fun to kick 'lil fart-can's asses on the gravel lots. handling, of course, was a different matter entirely. i got the honda through a deal- i didn't choose it, although i can't say i was unhappy with the car that i got. but i think it's my duty as a car-geek to make it as fast as i can :D slantsixness 05-10-2004, 06:51 AM this has turned out to be a fairly long thread, that's kind of gotten off the track... did anybody notice that Bowza can't spell Daytona...? HA! Geeko 05-10-2004, 01:47 PM oh... heh. i thought it was a euphimism- like i've heard them called Gaytonas (typically when they are having problems with a car :D ) what is more interesting is the fact that the title to this thread makes very little sense, unless you are high or very, very drunk :lol: slantsixness 05-10-2004, 01:59 PM A guy with a 5.0L Mustang GT awhile ago (summer of'93??) called my '90 VNT a "Gay-tona". I ripped him a new behind in the 1/4.... so maybe that was gay? I didn't try to influence my car's preferences, but it always seemed to keep it's ass out in front of everybody! (mind you, "everybody" was everybody I raced. I knew well when the car was well out-classed....) :) It was amazing how many excuses the guy came up with as to why his ruststang lost... Bowza 05-11-2004, 08:45 PM my name is jay..i drive a daytona..Go Figure how i put Jaytona together the title, if you had read my initial post, states that my car is cutting out after i reach 13 psi or so at wot..im just wondering if it is my map sensor or whatever regulates my psi doing its job..or is it something else..i found it to make alot of sence..but sorry you couldnt help me at all..and iono how this turned out to be a completely off topic thread..but anyways..cheers slantsixness 05-12-2004, 08:13 AM Bowza You need more fuel, and more air mass. consider a riser plate for the throttle and an adjustable Fuel regulator. maybe a reprogrammer for the computer could help too, but the fuel air ratio is probably what's killing you @ 13psi. There are a LOT of other things tou can do, but it's gonna cost you a LOT of dough to do it. regardless that we've mooched your original thread, we've all had fun! Slantsixness crash8168 05-16-2004, 12:57 PM Youre in overboost territory. It shuts off the fuel to prevent destroying the engine. slantsixness 05-17-2004, 07:46 AM Overboost, I'm having visions of the guy who gives you a leg-up and instead vaults you over the horse......hmmmm overboost.... nah.... More fuel.... Must have more fuel.... Must have larger Air intake volume.... 15-17LBS of boost? you'll have a better chance of hurting something. 12-14 is manageable... If it's REALLY 12-14. Bowza's lucky it isn't more like 10.5 realistically. Turbo guages usually just suck. Ok, so you disagree? Don't be so naive. You just have to know how to control what you do. Destroy a 2.2/2.5L? Highly unlikely if you did things right. Stay away from NOS. It's just making YOU too happy. Slantsixness And geeko's "mystery ride" sounds like a delivery truck, or a tractor trailer. Hell, maybe its a tour bus! Geeko 05-17-2004, 01:04 PM *notes that Slantsixness says his dodge engine is "indestructable"* so... if i run 15lbs of boost through it, and a 300 2-stage shot of NO2, and it blows, you do the repairs, right? :p having a semi to cruise in would rock... actually, i've been looking at a retired greyhound for an RV/car hauler conversion. my "mystery" ride also gets infinite MPG (of gas)... it's an old-skool Schwinn racing bike ;) good for when the gas hits $2+ per gallon. i'm quitting my job that's 70 miles away, and going to work 1/4 mile from where i live. that's like 200 bucks more a month i have to spend on car parts! :lol: crash8168 05-17-2004, 09:23 PM Im serious we saw it many times in the dealership with faulty wastegates. The engine controller monitors boost at the map sensor and shuts it down to protect the engine. While it cant actually limit boost it can keep it from getting too high by shutting down the engine, so you get a stutter of on and off. slantsixness 05-18-2004, 07:13 AM Geeko, NO NOS NO NO NO. I said "STAY AWAY FROM NOS, IT's JUST MAKING YOU TOO HAPPY" In case you didn't know, Nitroous Oxide is "Laughing Gas" from the old days. (it was a Joke) You got me on the Mystery ride... but I had to guess! You run NOS in a 2.2 or 2.5L turbo, you will be sorry, unless there's so little you actually use that it's just for show so you can look "cool" with a bottle strapped under the hatch..... Crash- How many BMW's have Chrysler 2.5L turbos? There are several aftermarket proceedures, hints and kinks that chrysler and Carroll Shelby still don't know. So, you're an automotive technician.... and maybe you used to work for Chrysler...? Point is, if one of my turbo cars had ever been back to a "dealer", they would have said my computer was missing (what was that big yellow box...?, that I voided my warranty when I put that turbo on there, and that there was far to much polished aluminum under the hood. While the wastegate Stutter is a common problem, you can set up the 2.2/2.5's and their respective turbos (and aftermarket ones) to perform fantastically, beyond the so called "overboost" or "default limits". You think Chrysler made a factory setup perform at it's optimal limits? everybody else, I have spent many years, and many seasons with about 12 different chrysler FWD turbo cars. The Daytona/Lebaron is the best overall performer for handling (when modified) and consistent performance. Now, it's 2004, the 2.0 is a POS, the neon makes me want to gag. But that's not t he reason I DON'T do this anymore. I have a wife, a wonderful daughter, a life and a great job. No time for turbo cars, and the huge amounts of money spent on them. I'm lucky I get to spend time on my Dart GTS clone, which, for you people interested in old muscle, I hate to disappoint you, but it's a slant six (well, the short block is), and not a 383.... But why is there fuel injection, a big blue box, two throttle plates and two big round things in the exhaust, and what are the two extra "radiators" for...? I'll tell you in about two years when the suspension and body are finished. By the way, it's street legal, too. Slantsixness (Old School with new tricks) Geeko 05-18-2004, 09:20 AM Geeko, NO NOS NO NO NO. I said "STAY AWAY FROM NOS, IT's JUST MAKING YOU TOO HAPPY" In case you didn't know, Nitroous Oxide is "Laughing Gas" from the old days. (it was a Joke) You got me on the Mystery ride... but I had to guess! You run NOS in a 2.2 or 2.5L turbo, you will be sorry, unless there's so little you actually use that it's just for show so you can look "cool" with a bottle strapped under the hatch..... well... my only dodgemobile is a 4D, not a hatch... and you DID know i was kidding, right? NOS is fun... but only for a quater-mile at a time... i go for lasting power ;) "There is no old school, there is no new school... there is only car school, and schooling wannabe's" slantsixness 05-18-2004, 11:19 AM Sorry 'bout the "hatch" thing. This did start as a daytona thread..... jaytona actually..... I did know you were kidding.... but there are scary people out here that might think you weren't...... How did your 2.5L end up a being a Mitsu engine.....??? Geeko 05-18-2004, 02:37 PM Sorry 'bout the "hatch" thing. This did start as a daytona thread..... jaytona actually..... I did know you were kidding.... but there are scary people out here that might think you weren't...... How did your 2.5L end up a being a Mitsu engine.....??? the 3L v6 model had an admitted mitsu engine in it, and afaik the engine in the 2.5 is mitsu in design & fittment, and (maybe) dodge in manufacture. mitsu and dodge have been sleeping together since the early 90's, and have ended up with some serious bastard offspring :D 90G-T1 05-18-2004, 04:31 PM Okay, so I'm assuming you have a stock Mitsu turbo. If you do then that's your problem. With the stock T1 turbo you can't open up the exhaust without getting some boost creep, which is probably what's happening to you. If you want to fix it you can either switch to a Garrett turbo out of a TII, or you can put some sort of restriction in the exhaust. If that still dosen't do it then go to turbododge.com and browse through there for a wile. You should find what you need pretty quick over there. crash8168 05-18-2004, 11:03 PM my name is jay..i drive a daytona..Go Figure how i put Jaytona together the title, if you had read my initial post, states that my car is cutting out after i reach 13 psi or so at wot..im just wondering if it is my map sensor or whatever regulates my psi doing its job..or is it something else..i found it to make alot of sence..but sorry you couldnt help me at all..and iono how this turned out to be a completely off topic thread..but anyways..cheers wastegate is not working properly. fix it. slantsixness 05-20-2004, 08:36 AM 2.5 and 2.2 are NOT mitsubshi motors. 3.0 V6 IS mitsu. :disappoin Garrett's are great! But there are better..... :evillol: Your wastegate is not the problem. :nono: I'll shut up now. :) Slantsixness Geeko 05-20-2004, 04:07 PM well... crap. what about the 2.3 in the R/T? yes, i WOULD kill for one of those. even just then engine & tranny. :naughty: 2.5 and 2.2 are NOT mitsubshi motors. 3.0 V6 IS mitsu. :disappoin DaYtOnAt2 05-23-2004, 12:13 AM It's still a 2.2 in an R/T, just a twin cam and tons more power* crash8168 05-23-2004, 12:57 AM Yes i was dealership mech. still am. and the factory limit in the engine controller was conservative. point is he may still be running the factory controller with its limit on boost. to get around it you need either a different controller or modified controller. and BMW cars dont need turbos to make big power. Geeko 05-23-2004, 11:57 PM It's still a 2.2 in an R/T, just a twin cam and tons more power* not *just* a twin cam... the head was designed by Lotus... who is fcsking the shite at this stuff. site about the R/T: allpar (http://www.allpar.com/model/spiritrt.html) uuuuuhhhh... yeah baby i'll take one :naughty: slantsixness 05-24-2004, 07:11 AM Any body ever seen a Phantom? (mexican R/T (2.2L 16V)) 224 BHP for the Spirit R/T was conservative. if you use a 2.5L block and a turbo III cam and a little computer hacking..... hmmm... dyno stuck at 275 BHP @ 3650 RPM... how'd that happen....? You don't want to know how much it cost! But it'll blow your mind. Unfortunately, It blew up, eventually. Now it sits on my garage floor waiting for another $3K rebuild. how sad. I wasn't even driving it. Freinds don't let freinds drive 275 Hp turbo cars.... I was waiting for someone here to find out about the 16V head... There are amazing things the can happen with these little FWD cars.... if people would give them the chance... I know I'm not the only one who ever squeezed 275Hp out of a couple 2.2's and 2.5's. I know, I was beaten many times by people who had a whole lot more than me to spend, although I would say I spent a whole lot of time and money trying to catch up to them! I'll say again, at the present time I have no desire to race (on or off track) anymore. I want to see my kid(s) grow up and go to college, which costs too damn much these days...:) Slantsixness Ever seen a twin turbo 24valve fuel injected slant six? You will. BleedDodge 05-24-2004, 03:57 PM There was a guy on Moparts.org that hopped up his 225. Now it's awesome. My buddy's Eagle Talon is wicked fast. It has a bigger turbo than stock on the 2.0, along with the all wheel drive and everything, it's just about invincible in the wintertime. He still has this car, but he drives his 1996 GT Mustang all the time. I give him crap about it all the time, how that Talon would still smoke this Mustang all day, but he won't let me race the Talon against his Mustang. I'm sure the Talon would waste it. It's so fast. Geeko 05-25-2004, 08:57 PM hint hint, Eagle Talon == Mitsubishi Eclipse. and the AWD model did, indeed, kick ass. BleedDodge 05-25-2004, 09:19 PM hint hint, Mitsubishi Eclipse == Eagle Talon. My buddy has a Talon, I know they're just like the Eclipses. I don't get what you mean here. slantsixness 05-26-2004, 06:56 AM I've never liked the DSM cars, except the Starion/Conquest, which were pretty cool, but not quick enough and RWD. I agree they can be pretty darn fast, but I just don't like the way they look. I don't care what badge they're wearing either. they're kind of like honda's and Acura's. Just something I have never liked.... We got off the subject again. so what :) Geeko 05-26-2004, 11:32 AM subject? there was a subject here? My buddy has a Talon, I know they're just like the Eclipses. I don't get what you mean here. most import manufacturers excel at boosting the living hell out of a small-displacement engine. doesn't mean that domestics can't either, but that there would be the source of the talon's "kickass-ness". not that it makes it any less fun to drive ;) slantsixness 05-26-2004, 02:58 PM I thought this was all about Jay's fuel starved, computer robbed daytona....? Kicka$$ness? Slantsixness! BleedDodge 05-26-2004, 08:19 PM I wonder if he solved his problem..? DaYtOnAt2 05-26-2004, 11:44 PM Geeko- I wasn't underminding the R/T's powerplant just noting that even with a twin cam head ( whether lotus OR maserati) it's still a 2.2 not a 2.3. I wish I had the damn thing to start with in my Z. Would've been a more powerful base for the billions I've spent, than the T2 I have. I can't complain though, I am pushing over 400hp and 380ft/lb to the wheels. Oh BTW it IS streetable and pretty reliable too! (No more replacing head gaskets every couple months :banghead: ) Lots of time and trick work to get me there though. Geeko 05-27-2004, 08:53 AM naw man, 's cool, 's cool. just as long as she goes fast, that's all that matters ;) yeah... hey jay, you fix your car or what, man? not that we're going to un-hijack this thread or anything, but seriously, you get that problem fixed? slantsixness 05-27-2004, 12:15 PM Hmmmm.... A T2 at 400HP... A 2.2 twin cam motor.... hmmm..... A VNT with a twin cam and 2.5L block, oh yeah that's right, a 2.5L. It's zippy I tell you, zippy.... and then it got on a dyno.... hmmm..... having problems with that 400 HP mark from daytonaT2.... but hell, it's been six years since I've done any imporvements. What sux is that it's sitting on the garage floor, with a narcoleptic 2.5L in the daytona so it runs for my father in law, but there the damn burnt out bitch sits.... two wiped cams, bad followers, and possibly an unrepairable crack in an unreplaceable head. More or less, I'm just F$%^ed. My wife wants me to scrap it, since the car runs fine with the NA 2.5L, (but I left a T2 MPI on it anyway... just no turbo..) sometimes I miss this sh!T. I'll probably scrap the motor here soon, which after about $4K of work is a damn shame that my freind blew it up. (Jeff, if you read this, you're still not off the hook...even after 5 years..) Oh well, DaYtOnAt2 (or however you spell that..) How'd you come up with 400 HP? I don't care about the torque, really, I'm not trying to launch the F$$%er into outerspace like the original TV commercial said in '90,(boy that was dorky, anybody ever see that?) Just curious, Slantsixness (Now, the slant six in the GT is another story altogether...) DaYtOnAt2 05-27-2004, 02:27 PM It all started about 4 years ago when the lifters failed... Honestly the list of shit I've done is as long as I am tall, and I'd probably still overlook some stuff. These numbers are NOT attainable with simple bolt ons...well maybe for a few runs but not reliably. Put it this way, no bolt was left unturned. I'm currently using a reprogrammed ecu from fwd and still bleeding past their "preset" boost cutout of 18. With two seperate secondary injectors, I see 24-25psi in high boost setting on a regular basis. It does run a bit rich at idle and off boost due to 52# primaries but you know, "sacrifices" my friend. A custom T3/T4 makes it all happen from around 3200-7000. The .70ar compressor housing causes the lag but when you shift to second your not already halfway through the useable power anymore.Forged wiseco's and custom billet rods along with the stock forged crank keep it all together in the bottom. While the deck is o-ringed for the insane pressures. The head is the fourth one I've ported and polished myself (just to try new approaches not because anything was wrong with the others). A taft S5 profile regrind seems to do the trick but believe it or not i'm thinking of trying a stock roller T2 this year with the current head config. and maybe softer valve springs. It seems like I'm losing the boost through the exhaust valves at low rpm's. (The overlap is 48 deg.)No big deal though. My current setup does not "feel" as powerful as the previous but the power is more flat rather than spikey. This thing has no problem smoking centerforces DF cluthes in a few months or so. I've seen these things make over 500 with only a few different things here and there. Bigger IC and dual BOV's for safety, and most likely stand alone management. I dunno, I'm really not interested in redoing this all over again. After about the second year of having parts made rather than buying off the shelf, it becomes more annoying than anything else. I originally was shooting for a low 12 high 11sec car without completely stripping it and without having to make the suspension undriveable on the street. I think I'm there, and when I get back from vacation in florida in a few weeks I'll be off to the track to see. BTW I don't recall dodge using the 2.5 with DOHC in anything. I guess I didn't get the point to what you were getting at there. slantsixness 05-27-2004, 03:05 PM I did the 2.5L and the DOHC 2.2L motor merge. Suprizingly, your block sounds pretty close to mine, except I had to have a custom crank forged at a local shop. My daytona did hit 12.49 once, but usually it was tuck in the 13's, which is bad enough to scare the camaro/mustang RWD crowds. Centerforce clutches do that to you , too? I went to the automatic 3 speed and, regardless of their poor reliability, it rocked out the 12.49 with it. I let a freind run it several times, when I was out TDY one season, and after about (he said)10 runs, he wasted the cams and I think cracked the head, where I can't fix it. When I put it together, there weren't a lot of options for cams and followers, especially for the Lotus head, so they were custom ground, too. I don't have the specs in my head, but I was fresh out of college when I built it and I had a mech engineer/mopar buff freind do the math (i'm an EE). I never got the thing to do well with boost higher than 16-20 psi, but it was "spikey" as hell. max power was around 6300, and It's been to 8000 several times without turning the bearings into steel wool! (but I don't recommend this!) The bottom end is still good, and it still ran when I took it out of the car, but compression is way off in #2 (63#) and the cams I know are lunched, after I thought that was the problem. Even after it took a crap, it still pulled a 14.40, with the half dead cyl! But that's been 6 years ago. I did all the intake modifications, turbo and electronic managements. I built my "own" computer from a bastardized SMEC and a couple FPGA's (programmable Gate array Ic's) I still use the computer programmer design for my present cars, but I haven't attacked the Durango yet, besides, my brother's gonna buy it anyway! If you read through the rest of this, you already know that My father-in-law has the daytonanow, with an MPI 2.5L in it (T3 intake) with no turbo. The turbo and the spare turbo are slated for the Slant six Dart project. I find the older cars more fun, although considerably heavier, they're "nostalgic" and so's the slant. I never have liked having somethng everybody else had! Even if it doesn't turn out that fast, it sure makes people wonder what the hell is in there that looks like that. BleedDodge 05-28-2004, 01:03 AM Slant, it might be time to find new friends. If one of my buddy's did that to me I'd make them buy me a new motor. Were you guys drunk or what? Geeko 05-28-2004, 08:36 AM that really sucks, slant... yet another reason why i'm nervous about my friends driving my cars. everyone wants to drive my car, but it's like letting someone hold your newborn baby- "okay, you've held her, NOW GIVE HER BACK!" :D slantsixness 05-29-2004, 07:03 AM To make a long story short, I didn't forgive Jeff for toasting the motor, but he did help me build it, and I got sent to Germany for Gov't business for 6 mo's, and I had already registered the car for the season, so I trusted him. He did quite well with the car until it toasted. It's not like we can find another head and get new parts ground for it, so I just went back to a straight 2.5L with a T2 head and intake. Deleting the turbo was my choice, since my Father in law needed a bulletproof car to commute with. Of course, I got over all this almost 5 years ago! At the time it blew, I had a 3.0 daytona (An IROC) that I was considering converting to a twin turbo, but I sold it to buy a new minivan..(can't fit anybody in those back seats!) I went on with the twin-turbo/ DOHC slant six/ dart GT project, which to me, is more interesting now, but I don't get a lot of time to work on it lately. As for my buddy Jeff, he moved to Orlando FL with his wife, so he's a long way away, and he's fooling with old Datsun Z cars now, (guess he likes rust!) :) I see him about twice a year, when I go down there, and when he comes up here. inevitably, we'll end up in my garage and he'll apologize again for the dust covered 2.5 under the workbench! DaYtOnAt2 05-30-2004, 12:56 AM slant- have you checked with the local machine shops? Sometimes they can get things you wouldn't think they'd be able to, like that head that's creamed. BTW If you're aware of the 2.2's potential why did you question mine? There's really no point to me trying to BS you. Good luck with the slant motor though, from what I've heard the bottom end is bullet proof on those things out of the box. And you're considering a TT setup? I must know more... :evillol: slantsixness 05-30-2004, 06:50 AM the twin setup is functional, and this is the second time I've done it, although the first time I'll be using the DOHC head, to give you a small hint, the spark plugs are in the center of the chamber....:) Nonetheless, the twin setup is done with the 3.0 twin turbo setup, injection and basic computer from a VR3000GT. But, making this all work on a slant six is no small task. Custom manifolds (4 of them), custom head (aluminum!),custom ground cams,forged crank, custom pistons and rods, enlarged oil passages (and two turbo oilers) and a host of other necessities. With some luck, and a little help from my freinds, the thing should rock. It is mated to a 904 automatic, although I'm not sure it'll stay that way... It's not a real high compression motor, nor do I plan to take it to it's limits every saturday night. I'm planning to leave the A/C on the Dart, too. I know I could find a shop to "fix" the 2.5L, and I don't know whether the head can be "fixed".At one time, I thought it would be cute to throw it in the Dart, with a dakota trans, but sanity won out! Presently I dont have a car to use the 2.5L in, and when I get the Daytona back from my father in law, if ever (he could wreck it) I'll consider putting it back together again, but right now there's no room with the Dart in the garage for another project! Lucky for me, my wife doesn't know it's a whole motor, that's why it's hidden under the bench, and considered "Dart Parts", or she'd have my a$$! ( i promised her I wouldn't put the Daytona back together as a hot rod, for her dad to drive!) Slantsixness SVTcobra306 06-08-2004, 11:22 PM Back to the original question:: Jay, Your car is hitting overboost. As was said before, if you have an '89 or newer TI 2.5 liter engine, it has a tiny mitsubishi turbo on it. (Don't believe me? rip off your airbox and look!) You do have a wastegate problem. The problem is that the valve inside it isn't big enough to control the boost on that motor/turbo combination with opened up exhaust. Mine creeps with a hi-flow cat and full 2.5" system. Also as was said before, pay a visit to turbododge.com there is a wealth of knowledge there. slantsixness 06-09-2004, 06:32 AM I use the mitsu turbo as a doorstop in my garage. Come to think of it, it's probably still good, too. (not that it ever was "good"....) SVTcobra306 06-09-2004, 01:19 PM That's the future job of my mitsu, too. Or maybe I'll find a second one and TT my ranger.... Have a garrett ready for a rebuild.... BleedDodge 06-09-2004, 01:28 PM I have a SBC for a doorstop. SVTcobra306 06-09-2004, 07:49 PM I have a SBC for a doorstop. ROTFLMAO!!! :lol2: :lol: BleedDodge 06-09-2004, 09:57 PM I'm not kidding. Automotive Network, Inc., Copyright ©2012
