89 camry cluster swap
JeEpBoY95
04-29-2004, 08:11 PM
i'm swaping the original cluster that has the huge gas gauge for one with a tach from the same year camry, are all the harnesses and pulgs already there or do they have to be installed?
Toyrolla
04-29-2004, 11:39 PM
To my understanding, you just plug in the same connectors that are there. One of the leads of the multi-pin plugs gives the reading to the tach.
JeEpBoY95
05-01-2004, 01:02 AM
thanks for the info. it went in with same connections and the tach works but the speedo seems a little off, the original one went up to 140 and this one goes up to 150.
Toyrolla
05-02-2004, 11:18 PM
The cluster you have is for the V6. If you have the 3S-FE engine, then you need to get the 4cyl cluster.
