What turbo is suited for me?Tmack240 04-28-2004, 09:59 PM Im new to the whole turbo world, and i'm looking to turbo a KA24de. It's going to be a daily driver. I would like to have at LEAST 250 hp at the wheels. Tell me what turbo's would be good for me. Tmack240 04-28-2004, 10:08 PM And I would like to run between 7 and 10 pounds of boost. I have looked at a lot of turbo's, but i dont know the difference between them. Thanks. pantlegz 04-28-2004, 11:05 PM J SPEC SilEighty 04-28-2004, 11:18 PM Since you're new to turbocharging then the best bet would be to buy a premade kit. Check out the kits from Nsport, XS Enginnering, FMAX, and Real Nissan. Greddy makes one as well, but I, along with many others, aren't too fond of greddy kits. Since you said you don't know the difference between turbo's and if you really feel like putting together your own kit then I recommend going to your closest bookstore and buying Maximum Boost by Corky Bell. It's crazy how much you will learn about turbocharging a motor from that book. But for 250 whp, you can make that at 7psi with a T3/T4. 60 trim compressor wheel, .60 A/R T04E housing. .63 A/R turbine housing with a stage 3 wheel. You can upgrade to the stage 5 wheel for more flow, but it's not required. Hell, not sure if you've heard of him or not, but the guy who owns www.ka24de.com made 410 whp at only 17.5 psi on that same exact turbo I just told you to use. He even used the stage 3 wheel that it comes with. That just shows you the potential of that turbo. Quick spool + great power. sleeper240 04-29-2004, 04:03 AM I thought Real Nissan was out of business? turbo2nr 04-29-2004, 10:08 AM damm u j spec- beat me to the punch... i like the t04b .63 a/r its pretty decient and you can build 250hp easily i suggest getting a smalle wheel tho.. if u want quicker spool up but be prepared to sacrifice some topend power for lo-end acceleration.. 1 Tmack240 04-29-2004, 10:01 PM I have a buddy that is selling his T61 (i think that is what it is) he is getting 397 to the wheels right now with it. he is getting a t66. anyways, he can put a setup for me no problem, but i dont know if that turbo is too big for me to get quick spool. will i have to wait till like 4k RPM's for it to kick in? i know its not possable to have the best of both worlds, but what turbo would be a mix of low and high rpm boost... thanks turbo2nr 04-29-2004, 11:55 PM we cannot determine that without a a/r size and wheel size, just a tip b4 you ask any question about a spicific turbo application get a a/r and a trim size so that we can be able to give you a detailed answer. 1 J_Spec_NiTeMaRe 04-30-2004, 02:35 AM 7-10 lbs of boost huh? May I suggest this (http://www.hksusa.com/products/?id=817&rsku=) little guy? RedRain 04-30-2004, 11:30 PM T3 .60 compressor and a .63 turbine if you are not going to run more then 10 pounds of boost. 240sxAddict 05-02-2004, 06:56 PM dang this guy beat me to the question Tmack240 05-04-2004, 04:47 PM Sorry Tmack240 05-04-2004, 04:48 PM well i think im taking my buddies turbo, im getting it for less than half he payed, not to mention, im thinking about even more power. You always are! Anyways, thanks for the tips! Automotive Network, Inc., Copyright ©2012
