wiper problem: don't shut offadumas 04-28-2004, 12:18 PM 1993 Ford Escort Sometimes when I go to turn off my wipers, they stay on. And sometimes when I put them in intermittent mode, they start off correctly (wiping intermittently) but then slip into a speed that is close to the low speed setting. To get it to stop, I often have to let the wipers sit in low or high speed for a while, then move the switch to the off position. Any ideas on what needs to be replaced? I appreciate your help. Thanks! amature 04-28-2004, 08:45 PM Sounds like you need to replace your wiper motor. My brother had the same problem with his truck. The motor could be shorting out. I don't think it is your wiper switch. Jet-Lee 04-29-2004, 09:53 AM sounds to me like ur switch, i had same thing with my bronco, replaced the switch, all was good. mightymoose_22 05-04-2004, 03:01 PM Yep... start with the switch. It seems clear that the motor is working very well ;) Automotive Network, Inc., Copyright ©2012
