ls turbo vs b16 all motor
crabby760
04-27-2004, 11:21 PM
my friend has a 95 ex coupe with a b18b ls motor he's putting a t3 garret turbo on his car a basic kit running 8 psi also putting hondata all stock internals i'm curious if i will be able to hang with him with what i have done to my engine
93 honda civic dx coupe , jdm b16a
cold air intake
dc 4-2-1 header
2 1/4 inch catback exhaust
civic type r camshafts
aem true time cam sprockets
skunk 2 ecu
aem fuel presure regulator
vafc controller
aebs typhoon intake manifold
exedy street racing clutch
high flow cat
so far only BUTT DYNO but sometime within a month or 2 i plan on getting it professionally dyno tuned
LET ME KNOW YOUR THOUGHTS ON THIS ISSUE
DeleriousZ
04-28-2004, 02:09 AM
i am afraid you will get your ass handed to you on a silver platter my friend... he will be making most likely around 70ish hp more than you.. if his engine doesn't explode.. he will win for sure
crabby760
04-28-2004, 02:13 AM
is there anyway i can hang with him by going all motor.
with the mods i have im sure i can put down at least 170-180 wheel hp
wat else woudl i need to hang with him....
plus im a much better driver than he is
DeleriousZ
04-28-2004, 02:29 AM
hmmm, yeah swap in a b18c jdm type r and build the piss out of it... otherwise.. good luck:)
crabby760
04-28-2004, 02:32 AM
so there's no way to beat a stock ls turbo with a b16 all motor?
91CRXHF
04-28-2004, 02:34 AM
oh you could beat him with your set up there is no dought in my mind BUT you would have to strip your car out about 1000lbs my losing the back seat the passenger seat rip out the carpet and cut out the floor and put in aluminum sheet metal then take out your fuel tank and run a fuel cell that holds a gallon...and you should be about right...
DeleriousZ
04-28-2004, 02:38 AM
oh there is... but you'd have to spend quite the pretty penny... it wouldn't really be worth it unless you're dead set on staying all-motor. as like 91 crxhf said... rip everything out of it you possibly can... maybe chop off an arm and a leg or something too... get lyposuction maybe
i'm all about the boosting, so i'm hella bias.. just keep that in mind
crabby760
04-28-2004, 02:44 AM
wat is a good turbo set up to run on a jdm b16a with stock internals
crabby760
04-28-2004, 05:25 PM
with the mods i have rite now how do you guys think i wuld hang if i put a ls block with my b16 head and tranny ls/vtec do u th ink i would hang then?
vtec92civic
05-15-2004, 10:09 AM
yes there is but you need mre power mods.
Get some bigger injectors if you want to go all motor:
310cc
Cam Gears
Cam Shaft
work on your timing to get the most out of your motor. You could get rods and pistons (high compression) for all motor, but with what you have he will def. eat you alive.
