fuel pressure regulatorbugsas99 04-27-2004, 10:03 PM i have a 98 aurora can you please explain to me where the fuel pressure regulator is located and is it an easy job to replace??? RobertHammen 04-29-2004, 10:14 AM The FPR is located under the gray plastic engine cover. If you are standing in front of your car, it's on the back side of where the engine cover sits, to the right. The FPR itself is fairly small (about the size of 5-6 quarters) and looks like a small oil can. There's a vacuum line coming off the side of it, and it clips into a fuel line below. It's really a ten minute repair job, tops, the trick being to make sure that you remove the small o-ring when you take the old FPR out, and that you get the new o-ring to seat properly (use a little engine oil from off the dipstick). Once you get the part, you should have no difficulty in finding it under the engine cover... --Robert Automotive Network, Inc., Copyright ©2012
