Timing Belt ReplacementRedErick44 04-24-2004, 09:06 AM On this RAV4 the aftermarket replacement timing belt fits slightly loose. When the tensioner is adjusted all the way tight, the belt still has a little more give than i usually see in timing belt relacement. Is this normal or will a Toyota timing belt fit tighter? Erndog1369 04-25-2004, 05:00 PM Most likely the Toyota belt will fit better. I have seen some aftermarket belts that are loose. Automotive Network, Inc., Copyright ©2012
