rimsjoeyboxer 01-13-2002, 02:35 AM RIMz i was wondering if anyone could tell me if the bolt pattern on a neon is the same as the bolt pattern of a sunfire? KatWoman 01-13-2002, 03:05 AM I believe the Neon's bolt pattern is 5 x 100 with a 35-37 mm offset. Hope that helps somewhat. If you can't get an answer here Discount Tire (or a reputable tire/wheel shop where you are at) should be able to answer that for ya :) joeyboxer 01-15-2002, 01:26 AM thanks for the info:) i found out that a dodge neon and a pontiac sunfire have the same bolt pattern they are both 5x100 with a 57.1 centerbore Automotive Network, Inc., Copyright ©2012
