knock sensor 99 gmc truckwshultz 04-23-2004, 07:21 PM the code i receved told me bad knock sensor. can anyone tell me where i might find this on my 99 gmc? macktoschool 04-26-2004, 04:04 PM Remove the intake manifold. Underneath you'll find the knock sensor wiring harness, remove that. Remove the sensors. There's a TSB with regard to the GMC knock sensors whereas water will get on the rear sensor, and cause it to rust. You will see a gap at the rear of the manifold, where you will have to build a Dam with silicone to prevent that from happening. Good Luck Automotive Network, Inc., Copyright ©2012
