Tachometer, fuel gauge, oil pressure gauge not working.ky_horsetrainer 04-23-2004, 12:06 PM I have a 92 explorer. the gauges and tachometer are not working but the spedometer is any suggestions? P.S. checked all fuses amac209 04-26-2004, 01:49 AM remove the cluster, unplug it and clean the conection then plug it back in. if that doesn't fix it check the grounds under the dash. it's also possible theres a problem with the cluster, i'm pretty sure you have a printed circuit on the back of the cluster, look for any corosion or burnt circuits. good luck hopefully it's something simple ky_horsetrainer 04-26-2004, 08:40 AM i got it fixed. it was the some crossed wires. jits7 05-02-2004, 01:36 PM i have the same problem which wires are crossed? thanks Automotive Network, Inc., Copyright ©2012
