Cig lighter fuse
denito
04-22-2004, 08:46 PM
My lighter quit working. I looked at the fuses in electrical distribution panel, but all the fuses are coded. Non indicate Cig lighter. So without taking out every fuse could some tell me which fuse is the lighter?
They have markings like IIL ICC ICL etc.
Thanks
denito
burly
04-23-2004, 12:32 AM
Look on the actual panel that you remove to get access to the fuse block. I believe its on the passenger side's panel, at the end of the dash (you'll have to open the door to see the panel). On the inside of the panel that you remove they label the fuses with letters and have a legend next to the diagram. If you still can't find it, let me know and I'll check exactly which one it is.
e2helper
04-23-2004, 05:57 AM
If you have a 1997-2003 Malibu the cigar lighter fuse is in the underhood electrical distribution panel. You may not have looked there.
Cidthefallen
06-20-2004, 10:28 PM
3 places for fuses.. driver side passenger side and under the hood.. you can always resort to your instruction manual its in there and nice pretty pictures of it..
Harryc8786
06-25-2004, 02:18 AM
Hey guys i have a problem too with mine, and i dont think i have a fuse in the panel for the lighter adapters. I dont have a manual for my 98 so could anyone like send me a pic or anything showing which fuse(s) control the adapters, if anyone can than thanks
e2helper
06-25-2004, 03:22 PM
Actually you don't need a manual. Just pop your hood and look on left side for the underhood electrical center. On the inside cover is fuse information which will tell you which fuse is the 20 Amp minifuse for Cigar Lighter/Aux Power Outlet. Of course if cover is missing then you will need more information. It is the only 20 Amp (Yellow) fuse in the center so shouldn't be hard to find (#34 on label). Lower Left Quadrant assuming this fuse label shows stuff in car position.
