89 Escort idles super fast at times
Google
Web AF
allenb
04-22-2004, 09:20 AM
:banghead: My 1989 escort idles at around 4-5000 at times even when I shut it off and restart, it idles down at times but usually not...please advise me if anyone has same problem or can help....thanks
amature
04-22-2004, 09:54 AM
I have not had this problem but you may have to replace your idle control sensor. Look it up in a Haynes manual or ask a mechanic where it might be, I am not sure. Something is telling the computer to increase the fuel.
Jet-Lee
04-22-2004, 11:05 AM
make sure your throttle line isn't stuck, holding ur butterfly open.
'90 Escort Man
05-27-2004, 11:54 PM
I have a 1990 1.9 CFI automatic with same problem. I replaced throttle position sensor, improved problem for about a week. Went to junk yard and got another throttle position solenoid, no improvement. Will try engine error codes tomorrow. Will let you know results.
'90 Escort Man
06-09-2004, 12:34 PM
95% fixed. KOEO produced code 73 (ins. TP change) and running test produced 99 and 23 (both related to throttle position). Wiring diagram shows relationship with MAP. Rereplaced TP sensor, replaced MAP, reset codes... mostly fixed. Need to replace dryrotted vacuum lines for remaining 5%. Side note, check engine light never lit to show faults in system. Light works at initial key-on self test, though.
Google
Web AF
