engine turns over but doesnt start Help Pleasestorman 04-19-2004, 12:40 AM hi i recently over heated my engine and now i try and start it and it wont . i replaced the the spark plugs and wires and rotor and distibutor cap cause i thought it might not be getting enough spark. it sounds like it is going to start and it is about to turn over but then it just keeps doing the same thing over and over. Dale Aeppli 04-19-2004, 12:08 PM hi i recently over heated my engine and now i try and start it and it wont . i replaced the the spark plugs and wires and rotor and distibutor cap cause i thought it might not be getting enough spark. it sounds like it is going to start and it is about to turn over but then it just keeps doing the same thing over and over. HI CHECK FOR SPARK AT PLUG WIRE ALSO PULL CIOL FROM DISTRIBUTOR CAP TO SEE IF YOU HAVE SPARK COMING FROM COIL TO DISTRIBUTOR ALSO CHECK TO SEE IF YOU ARE GETTING GAS. DALE jeepman600@aol.com :banghead: storman 04-19-2004, 05:20 PM HI CHECK FOR SPARK AT PLUG WIRE ALSO PULL CIOL FROM DISTRIBUTOR CAP TO SEE IF YOU HAVE SPARK COMING FROM COIL TO DISTRIBUTOR ALSO CHECK TO SEE IF YOU ARE GETTING GAS. DALE jeepman600@aol.com :banghead: spark is coming into the dist cap and i replcaed all the sprak plug wires and such also fuel is getting into the injector pipe. might it be the icm ? comp 04-19-2004, 06:51 PM Can you smell fuel in the intake or exaust???? it may be at fuel rail and not going any farther..... :smokin: Dale Aeppli 04-19-2004, 09:43 PM spark is coming into the dist cap and i replcaed all the sprak plug wires and such also fuel is getting into the injector pipe. might it be the icm ? DID YOU CHECK TO SEE IF YOUR GETTING SPARK TO THE PLUGS DALE jeepman600@aol.com Automotive Network, Inc., Copyright ©2012
