Help Problem with my 1988 cherokee coolingstorman 04-18-2004, 01:03 PM I need help with my cooling system with my 1988 jeep cherokee. I have been having problems with it overheating which climaxed yesterday the 17th at 2 am in the morning. It was reheating aon the way home and i stoped and put water in the resevoir. I dove about 15 more miles and almost hom when i suddenly started loosing power as i pulled off an exit steam started pouring out of the hood and the engine suddenly stoped Please help me I need to drive it and i dont have another car arggghhhhhh What could it be and how do i check please Dale Aeppli 04-18-2004, 02:10 PM I need help with my cooling system with my 1988 jeep cherokee. I have been having problems with it overheating which climaxed yesterday the 17th at 2 am in the morning. It was reheating aon the way home and i stoped and put water in the resevoir. I dove about 15 more miles and almost hom when i suddenly started loosing power as i pulled off an exit steam started pouring out of the hood and the engine suddenly stoped Please help me I need to drive it and i dont have another car arggghhhhhh What could it be and how do i check please HI SOUNDS LIKE YOU HAVE A LEAKAGE & IT DROWNED OUT THE ENGINE IF YOU EMAIL ME DIRECTLY I'LL SEND YOU INFO. ON THE COLLING SYSTEM. I CAN'T SEND THRU THE FORUM DALE jeepman600@aol.com redteamleader 04-19-2004, 10:05 PM jeepmans da bomb on cooling. thanks jeepman Dale Aeppli 04-19-2004, 10:19 PM jeepmans da bomb on cooling. thanks jeepman HEY THANKS FOR THE FEED BACK ALWAYS GLAD TO HELP. DALE :banghead: ShootMyCars 04-26-2004, 01:13 PM As worst case scenario, may be the same problem I have... crack in the cylinder head between combustion chamber and water jacket. I have one of the Cherokees that have no radiator cap, so when it overheats, it boils in the overflow tank! Krucial 04-28-2004, 08:06 AM I have a 88 Jeep Cherokee with no radiator neck too and mine does the same thing. Any suggestions? BCBlues 04-28-2004, 10:51 AM Heres what I did and now my Jeep never looses a drop of coolant and never overheats. It works, and works well. http://www.automotiveforums.com/vbulletin/showthread.php?t=206558 89jeeplaredo 07-02-2004, 09:18 PM I have an 89 cherokee and I had a problem with my water pump it had about a 1/4 inch in play I replaced that and havent had a problem since debb718 07-19-2004, 07:56 PM i have a 87 xj mine would over heat replaced everything then found out was head gasket was blowen replaced it had know more over heating trouble Automotive Network, Inc., Copyright ©2012
