Power increasoing 94 camryAMinHtY 04-16-2004, 11:47 AM i got a Pod filter and a lil canon, wat can i do to increase the performance of my car without spending too much money. Like little things i can do to make it faster. oh yeha its an AUto. wat type of problems to 94 camrys usually have, i haevnt had mine car serviced in ages. Wat should i be checking if i want to give it a quick service Bossman 04-17-2004, 05:14 AM Check your owners manual under the Maintenance section for the type of service you need. red-in-la 04-17-2004, 11:53 AM For starters change the oil, oil filter, fuel filter, service the transmission, rotate the tires. Get the car up on a lift and check the brakes, ball joints & dust covers. Oil changes every 3k and trans every 12k or 12months is good insurance. DON'T use Jiffy Lube or Fram oil filters, they are Junk. Go here to find out about filters >>> http://www.scuderiaciriani.com/rx7/oil_filter_study/ Then push the button on the shift lever that says something like "PERF". It will change the shift point to a higher rpm for more peppieness. Regards Automotive Network, Inc., Copyright ©2012
