1997 Jeep Cherokee oil leakALLSTARS4 04-16-2004, 01:53 AM my cherokee is slowly leaking oil and it's coming from the oil plug......i tried to tighten the plug thinking it was loose but it wasn't....it's still leaking.......anybody have any ideas what could be wrong? any feedback on this would be great! thanks! alan111 04-16-2004, 08:15 AM The plug Should have a washer, the washer could be bad. If you can tighten it, than the threads are good. NulodPBall 04-16-2004, 09:00 AM If you're sure it's the drain plug and not just dripping off the drain plug from somewhere else you might have to pull the plug and apply some sort of sealant if just tightening doesn't work (RTV, Loc-tite, plumber's paste?). Just a suggestion... Ray Dale Aeppli 04-16-2004, 04:58 PM my cherokee is slowly leaking oil and it's coming from the oil plug......i tried to tighten the plug thinking it was loose but it wasn't....it's still leaking.......anybody have any ideas what could be wrong? any feedback on this would be great! thanks! HI LOOK ON THE OIL PAN IN THE BACK MAKE SURE THAT YOUR LEAK ISN'T COMEING FROM THE REAR CRANKSHAFT SEAL IF IT LEAKS IT WILL RUN DOWN THE BACK OF PAN TO THE DRAIN PLUG & IT WILL APPEAR THAT THE DRAIN PLUG IS LEAKING, CHECK THE BACK OF OIL PAN DALE JEEPMAN600@AOL.COM aamech 04-17-2004, 08:55 AM My 97 jgc has an oil leal also but it is coming from the intake gasket and running down the back of the engine. I already fixed a leak at the distributer oring. You might look there if you have'nt already. 95zj1 04-17-2004, 11:29 PM Could be coming from anywhere, moving down the engine to the lowest point then dripping. Try cleaning the engine then you can get a better look at where its coming from. I had a leak at the oil filter housing but I though it was a bad oil pan seal. :2cents: ccarballo 04-19-2004, 06:42 PM I had the same on a Grand Cherokee 93. 6L 4000cc. but was not coming from the oil drain plug, it was coming from the crankshaft seal, in between the engine and the gear. Clean it carefully (they sell cheap products to clean) and try to look exactly where is it coming from , At the Hanes manual there is a way to replace it without taking the engine out, but make sure if the leak is coming from crankshaft seal. Dsilver 04-21-2004, 01:48 AM I agree, clean the area and watch to make sure you know exactly where the leak is coming from, then go from there. Automotive Network, Inc., Copyright ©2012
