Indivdual thottle bodiesky_infiniti2000 01-11-2002, 02:56 PM Friend of mine pointed me to this website last night. Its and AUS company which makes an intake for the SR20. Think the name was EFI Hardware. these things can be had for about $800-$900 US. pretty slick. b-b00gie 01-11-2002, 03:21 PM Looks similar to the ones on the BTCC Primeras. ky_infiniti2000 01-11-2002, 03:25 PM Originally posted by b-b00gie Looks similar to the ones on the BTCC Primeras. EFI Hardware (http://www.efihardware.com/) Any one interested is seeing if we can get a group buy? G-Forces 01-11-2002, 04:48 PM I'm not sure that's something you'd want on a daily driver. b-b00gie 01-11-2002, 04:54 PM Yeah, thats not for a street car. ;) P10DET 01-12-2002, 01:16 AM Originally posted by ky_infiniti2000 Friend of mine pointed me to this website last night. Its and AUS company which makes an intake for the SR20. Think the name was EFI Hardware. these things can be had for about $800-$900 US. pretty slick. Yep. And the engine management system will only set you back about $2k US. :D b-b00gie 01-12-2002, 11:53 AM You need to use MAP sensing with that correct? (guessing) ky_infiniti2000 01-12-2002, 01:05 PM Originally posted by b-b00gie You need to use MAP sensing with that correct? (guessing) i would think using rpm vs. airtemp vs. air pressure/density... have you ever heard of the Autronic? http://www.turbofast.com.au/autronic/autronic.html A380Driver 01-12-2002, 03:31 PM What kinda gains would this be giving you? Is this something that you would put on only after you've been running like 250HP+? P10Skin 01-13-2002, 03:01 AM Id be keen to see sum dyno results for them!! just out of interest even if they dont preform theyd still look pretty phat hanging off ur engine:D HAHA G-Forces 01-13-2002, 10:01 AM Originally posted by A380Driver What kinda gains would this be giving you? Is this something that you would put on only after you've been running like 250HP+? You're looking at some serious cash layout for something like this. First you would need something to measure the air coming in. You'd either need to build a new plenum and use the stock MAF or rig up a MAP sensor and some some custom ECU tuning or a stand alone system. This is strictly for racing. I guess you could use it on the street but it would probably cost more than a 350hp turbo setup! :D Just my opinion of course. A380Driver 01-13-2002, 03:52 PM Hehe no thanks :) I wonder if anyone has used it effectively yet tho? qab5b 02-19-2002, 11:02 PM Individual throttle body setups are perfectly streetable if one uses a MAF or AFM. Case in point: BMW M-cars have used individual t-bodies for years (except the 95-99 US M3, which is basically a bored and stroked 325/328 engine). Working from the air filter backwards here is how bmw does it. Air Box/Air Filter assembly to AFM or MAF MAF/AFM to Plenum (air collection chamber) Inside of plenum are tuned intake runners Intake runners to t-bodies (all 4,6, or 8 t-bodies must be in sync for optimum performance) Tbodies to Spacer Gaskets Space Gaskets to Head. THe fuel is injected post t-bodies but before the spacer gaskets from a common fuel rail. Even the typical mid 80's Motronic (or Moronic) can handle this. Its nothing that a good ecu programmer with some dyno time can't work out for the Nissan ECU's in a few hours. When you start using MAP and TPS sensors for engine load, you start to require some adjustability and tuning, which makes these setups less streetable. BMW used a TPS and MAP setup on their touring cars (nissan most likely did the same). These setups are wonderful for engine response, just a pain to maintain. Hope this helps. P10DET 02-20-2002, 01:44 AM Originally posted by qab5b Individual throttle body setups are perfectly streetable if one uses a MAF or AFM. <snip> When you start using MAP and TPS sensors for engine load, you start to require some adjustability and tuning, which makes these setups less streetable. BMW used a TPS and MAP setup on their touring cars (nissan most likely did the same). These setups are wonderful for engine response, just a pain to maintain. Hope this helps. MAF, AFM, MAP, whatever. If you have a single inlet tract and a plenum, it really is no different from tuning for a single throttle body. b-b00gie 02-20-2002, 08:21 AM Originally posted by qab5b Individual throttle body setups are perfectly streetable if one uses a MAF or AFM. Of course. The GTI-R SR20DET uses individual throttle bodies. However, the setup in the picture shown above is different, and is something used on NA SR20 race engines like the ones in the BTCC Primera's. This setup is for race vehicles. qab5b 02-20-2002, 12:50 PM MAP sensor setups on individual t-bodies is a bit trickier, as you need a chamber between the vacuum lines and the map sensor because MAP sensors tend to be affected by the sometimes large intake pulses of these t-body setups. In order to make this setup streetable, you would need to run a setup with a tps and/or map sensor in place of an afm/maf (using something like the Link Electrosystems AFM Link). Automotive Network, Inc., Copyright ©2012
