No spark
deano67
04-15-2004, 12:02 PM
My car ran fine yesterday morning to work, when I went out to go home car would not start, was able to troubleshoot and found there is no spark going to any of the spark plugs. I checked all fuses and relays all are good. Any suggestions on what it might be.
lowsonoma1999
04-15-2004, 02:34 PM
How many miles do you have on it. If you have less than 60k, it's still under the factory warranty. It could also be a coil. Check and make sure you have power going to the coil, if nothing coming out, then that is probably the problem.
deano67
04-15-2004, 04:44 PM
Thanks LOW it less than 60k but I am not the original owner, I will check the coils tonight looks there are two is that correct?
lowsonoma1999
04-16-2004, 09:27 AM
2nd owner still gets a 5yr 60k bumper to bumper. Only downfall for a 2nd owner is powertrain goes down to 5yr 60k instead of 10yr 100k. So it is still under warranty.
