Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mazda > Millenia/Xedos 9
Old 04-14-2004, 11:19 PM   #1
JSutton1
JSutton1 Normal reputation
Millenia Engine 2.5L Questions
Hi Folks,
I have some questions about a 97 Mazda Millenia 2.5L that I am working on, but first a short history.
This car was given to me after the owner damaged the radiator and seized the engine up. I completely tore it down, had it bored out and rebuilt it. The engine had gotten so hot when it seized that some of the plastic components, like the knock sensor, had melted. I replaced everything that looked bad, like the knock sensor (not cheap).
The car is running now, codes are clear, gas mileage is not so great, around 16. But I have two remaining problems I was looking for help with before I turn it over to a professional.
1. When I start the car cold in the morning, there is a metallic tap that develops in the left rear (Pass. Side) of the engine. It last for a short while, minute or so then goes away. My first thought is the timing belt tensioner. I have used a stethoscope and it seems to come from that spot. Any ideas?
2. My other problem comes when the engine is warmed up, at idle it tends to miss, not continuous. Just a miss here and there, maybe every 15 seconds or so. I have checked all my sensors. My plugs, wires, and compression all look good. Dist. parts are not new but appear good. I have looked for vacuum leaks? What else could it be? Could it be exhaust back pressure? The car seems to have plenty of power.
Thanks for your help,
Jim
JSutton1 is offline   Reply With Quote
Old 05-06-2004, 06:52 PM   #2
chucho692u
chucho692u Normal reputation
Smile Re: Millenia Engine 2.5L Questions
in regarrds to your millenia knocking ist easy hydraulic belt tensioner on al v6 626 millenia engines must be replaced every timing belt.most people dont but. when the tensioner looses its tention it knocks against
the tensioner pulley it took me 1 year to figure this out on my millenia
if you take the timig belt cover and start the engine you could see it vivrating u must have the pulley to start the car [
Jim[/quote]
chucho692u is offline   Reply With Quote
Bookmarks
Google
Web AF
