Help I'm Smoking
kaoticivic
04-13-2004, 11:11 PM
Ok some one please help me out. I started up my civic 2day and a steady stream of smoke came out of my PCV breather on the valve cover. I opened the oil fill and smoke started coming out of there too. The smoke was white and came out and up in a steady stream, kinda like a chimney. What gives? I've got a B16A with a full race T3/To4E set up. I checked the charge pipe but didn't find any oilo so I don't think I blew my turbo seals. The turbo is brand new and is Greddy. There is some smoke that comes out the exhaust from time to time at full open throttle. I have an oil leak around the oil pan gasket (new one should be here any day now). I'm stumped, what should I do next or what could it be? Anyone?
BrokenLimits
04-19-2004, 02:05 PM
If you checked the oil level, it might be low on oil. Also it actually sounds like the head gasket...
1995 geo tracker
04-19-2004, 03:54 PM
sound likes your rings are shot , you are getting alot of blow-by , that is what is causing the smoke
jeffseby
04-19-2004, 07:44 PM
how old is that b16 and how much boost were you running?
DeleriousZ
04-19-2004, 07:48 PM
white smoke means burning oil... not sure what is is.. could be rings or head gasket as mentioned before, but i can tell you that you're not in a good place right now :(
maxspeedhonda
04-19-2004, 10:12 PM
If you are blowing smoke out the valve cover breather then you most likely have a bad piston ring. It is letting an excessive amount of blowby which is burning causing smoke. I am willing to bet if you do a compression test, one or more cylinders will be significantly lower.
Thepeug
04-28-2004, 06:55 PM
Nicoderm CQ works wonders :wink:.
Tranzlogic
04-29-2004, 04:56 PM
rings rings rings my friend
whtteg
04-29-2004, 05:04 PM
time for a rebuild. How much boost were you running?
