Re: truck just dies while driving down the road
well, do you still have spark? When it dies pull a plug wire off and see if you still have spark, if you don't could be the CPS sensor, the computer, or the coil. If you do, chances are you are not getting fuel. Push the pressure releif valve on the fuel rail coming up to the engine and see if you have pressure, if you don't, it could be a bad pump, regulator. If you still have pressure and spark when it dies, could be a CPS sensor, or temp sending unit ( telling the PCM it is warm when it is still cold)
