Re: i fell victim to another trans failure
Ok they started making the A604/41TE back in 89 and the rebuild kits are for 89 to 03 so the internal parts are the same, So are the cases the same ?? and I think in 91 they went with a 24 spline 10.75 inch torque converter and before that it was 10 inch I think but they where all 24 spline ....
And some where I hear there was one that had a cut thru the caseing to allow for a collant line to pass thur it ?? nothing you can't install or remove with a welder/cutting torch ....
Don't know if this helps but I to have to replace the transmission since I put the diff pin thur the case and spyder gear thur the transmission ... So if you find out for sure let me know ...
And the A604/41TE was used in alot of dodges FWD cars and vans from 89 onward.... might be worth a trip to the local wrecking yard and just take a look at them ....
Creative ...........
